installing bell housing first before engine
Old Sep 16, 2016 | 02:04 PM
sunbelt57's Avatar
sunbelt57
A friend of mine said he would help me put my engine back in after a rebuild. He claims it would be easier to install the bell housing first. The truck is a 1977 4x4. Is that a standard practice?
Old Sep 16, 2016 | 02:15 PM
HIO Silver's Avatar
HIO Silver
Not standard.
What is the reasoning behind his recommendation as to "easier"? Lack of a "wobble" socket adapter?
Old Sep 16, 2016 | 04:55 PM
sunbelt57's Avatar
sunbelt57
I guess because you can make sure the lever is on the throwout bearing. Not sure what a wobble socket is. I have a clutch alignment tool and a level adjuster for the hoist.
Old Sep 16, 2016 | 05:09 PM
dlburch's Avatar
dlburch
Standard practice in my opinion...I've always installed as much as possible (including bellhousing) BEFORE putting engine back in. much easier than laying on your back trying to start/tighten bolts...and required if your trans is still in the truck. :-)
Old Sep 16, 2016 | 06:29 PM
ronspolv's Avatar
ronspolv
My opinion, not only put the bellhousing on the motor out of the truck, but slide the trans on to. Put it in as one assembly, much easier to align everything out in the open. Then slide your transfer case on once its in the truck.
Old Sep 16, 2016 | 09:03 PM
dlburch's Avatar
dlburch
And my ASSumption was you meant install the bell housing on the engine first.
Old Sep 17, 2016 | 03:17 AM
sunbelt57's Avatar
sunbelt57
Yeah, I should have asked: should I put the bell housing on the tranny (which is still in the truck) or leave it on the motor (where it is now).
Old Sep 17, 2016 | 04:43 AM
HIO Silver's Avatar
HIO Silver
Doing so will result in more chance of knocking off the throwout bearing from the clutch fork cuz now it require threading the input shaft through the bearing and then into the back of the crank.
With the bell on the trans, all ya gotta mind is splining the trans input shaft.
..pick your poison.
Old Sep 21, 2016 | 07:26 AM
sunbelt57's Avatar
sunbelt57
We put the bell housing on first - I think if I had it to do over again, I would have put the bell housing on the engine. The truck is 4x4 with a married tranny so I didn't want to take the tranny out.
Old Sep 21, 2016 | 08:10 AM
Filthy Beast's Avatar
Filthy Beast
In your first post you didn't mention the front clip was pulled or if the driveshaft was off.
I'm of the opinion to keep the bell on the trans. No matter, the engine is in now and, nice job. Looks good.
85bullnose250
15
Mar 25, 2025 08:57 PM
Eagle Custom
Jun 6, 2010 01:51 PM
mj_wyoming
Mar 17, 2010 10:10 AM
jemini
Aug 23, 2007 12:23 PM
E30tdf
Oct 24, 2006 11:08 PM
