Enable Exhaust Filter - WITHOUT DEALER
#106
Saw you had posted instructions a year ago on how to enable the exhaust filter % on the console screen in a F250. I have a 2014 Super Duty. The details in your instructions are no longer visible - can you repost?
I did find this:
https://www.ford-trucks.com/forums/1...readsheet.html
and it contains these instructions....
This adds the DPF % screen to the Truck Information screen. Some trucks will report a camera error after making this modification. To avoid that, make your update according to the following: If your original default value is 0, change to 8; if 1, change to 9; if 2 then A; if 3 then B; if 4 then C; if 5 then D; if 6 then E, if 7 then F (as shown).
But not sure where to get to them in forscan, or if these will work for a 2014.
Anyway - would be greatful if you could help out.
Thanks,
Gregg
I did find this:
Thanks,
Gregg
#107
You need to change the values in the IPC section (720-01-01) with FORScan.
You can look up items on this spreadsheet
https://docs.google.com/spreadsheets...AtI/edit#gid=0
Change for Exhaust Screen.
#108
@Just Strokin the spreadsheet says 2016 at the top & I have a 2014. I’m trying to turn on my dpf % screen & enable the fog lights w/ the high beams. I assume that the red digit on the spreadsheet is what you’re supposed to edit the value to but I get an error message when trying to write it to the ecm. The bambi mode accepted the changes but it didn’t enable the fog lights. ? Any advice is appreciated.
#109
It should work for your 2014 also. The 2013-2016 are all basically the same. The 2011-2012 radios and HVAC controls were different but most of the mods work.
Did you try making one change at a time and save it? Maybe someone with a 2014 will chime in and tel you what they did to get it to write.
#110
Let us know.
Keith
#111
Thanks @ZooDad for your reply. I figured it out. I disconnected my truck & exited out of Forscan & then tried it again & it worked. I was hoping to get my mirrors to do the auto fold w/ the remote like some of the ‘17 & newer truck owners have done but I haven’t had any luck finding anything about that with ‘11-‘16 owners. You ever come across any of that? Thanks again & have a nice weekend.
#112
Have a great weekend
Jetsco
2017+ Super Duty
17
12-02-2023 07:40 AM
