Carburetor
Old Sep 12, 2016 | 05:57 AM
BGF100's Avatar
BGF100
Carburetor
Hi, I have been having problems with my truck idling too high as I pull up to lights etc. If I blip the throttle the revs come down.
I noticed the other day at home under the hood that when I operated the throttle. Half a second later I could see fuel appear where I have marked on the photo (and have been able to clean easily).
I guess this could be a warn throttle shaft bushing? Thanks
Old Sep 12, 2016 | 06:44 AM
matthewq4b's Avatar
matthewq4b
I would say worn throttle shaft also. It is likely causing the throttle plates to hang up on the bore. A quick fix for the interim would be to put the return spring on on the bottom side of the throttle shaft (hooked around the throttle cable ball stud) then hook it to a tab fabbed and mounted under the fore intake bolt for the #8 inlet port. This should pull the the throttle shaft back so the plates are not hanging up in the bore. This would just be temp fix till you get the carb rebuilt or replaced.
Old Oct 23, 2016 | 03:48 AM
BGF100's Avatar
BGF100
Hi,
yes I guess its ok to undo the bolt for #8?
It doesnt have to be torqued to a certaim value?
Thanks,
Old Oct 23, 2016 | 04:00 AM
redcreekauto's Avatar
redcreekauto
I've been turning wrenches for over 35 years now and in that time I've seen many throttle shafts and bushings worn to this point with one resulting in a fatality. Yes you can move the spring or even add a stronger one but you could also find it may lock the throttle open to a position where it is dangerous. For safety's sake either have the throttle plate bushed and the issue corrected properly or get a new carburetor. Sometimes the cheap way out just isn't worth the risk.
Old Oct 23, 2016 | 04:06 AM
BGF100's Avatar
BGF100
Hi redcreekauto,
a new carburetor went on it this morning.
Still getting the over rev issue. Not as bad, but still anoying to me.
The question. I can reove the #8 intake bolt to fit a bracket?
Are they torqed to a certain vale?
Thanks,
Old Oct 23, 2016 | 04:17 AM
redcreekauto
Yes you can remove it to fit a bracket. I'm not sure of the torque but it would be around 25 - 30 Ft-lbs I believe.
Old Oct 23, 2016 | 06:26 PM
Blue and White's Avatar
Blue and White
Sometimes the linkage gets sticky. A shot of WD40 has helped me with this problem before.
Old Oct 23, 2016 | 07:22 PM
dlburch's Avatar
dlburch
I would suspect the throttle cable, make sure it doesn't have any breaks in the coating and it's routing path is smooth with no heavy bends...
Old Oct 23, 2016 | 08:43 PM
F-250 restorer's Avatar
F-250 restorer
I had nearly the same issue. Do you have an electric choke? My alternator was on the way out, and only supplying low voltage to the choke. So the choke was not opening all the way, and staying on fast idle.
Who would 'ave thunkt it?
blackenedbodom
1978 - 1996 Big Bronco
Mar 11, 2011 11:27 AM
hittman1422
Jan 3, 2010 06:08 PM
98FordTruck
1997 - 2003 F150
Feb 14, 2008 03:11 AM
himmelberg
20
Mar 29, 2005 10:46 PM
Firewiz
2004 - 2008 F150
Jun 14, 2004 04:57 PM
