1978 - 1996 Big Bronco
throttle kicker
Old Mar 11, 2011 | 03:56 AM
blackenedbodom's Avatar
blackenedbodom
throttle kicker
hi there ive got a 84 bronco xlt and i have recently rebuilt the carb. im pretty sure its a motorcraft 2150 2bbl. it has a throttle kicker solenoid on it but when i was putting it back together it didnt seem to line up with the throttle lever. do i need the throttle kicker? also what exaclty does it do? thanks
Old Mar 11, 2011 | 11:03 AM
Matt In Detroit's Avatar
Matt In Detroit
Usually bumps up the throttle for A/C. If you have working a/c you will want it.
I guess i would question why it does'nt line up.
Old Mar 11, 2011 | 11:04 AM
greystreak92's Avatar
greystreak92
I was under the impression for a time that AOD-equipped trucks needed the kicker to keep the throttle valve cable in position as the truck slowed down. (A controlled downshift in the AOD). This may or may not be true but I had it explained to me this way at one time.
Old Mar 11, 2011 | 11:27 AM
Matt In Detroit
You said solenoid, does it have an electrical connector? does the shaft kick out when energized? if so, probably a/c. If not it is likely an anti stall dashpot as grey mentioned.
LARIAT 85
17
Feb 27, 2022 04:02 PM
LARIAT 85
Sep 21, 2013 12:54 AM
beartracks
Oct 31, 2011 02:05 PM
soxfan81
2004 - 2008 F150
Mar 2, 2008 03:57 PM
borisman
4 Cylinder Engines
Apr 26, 2002 04:12 PM
