Shifter roll pin replacement
Old Sep 9, 2016 | 09:33 AM
HoustonDave's Avatar
HoustonDave
My shift lever has always been sloppy ('78 300, C6, column shift) - looks to me like the looseness is because the roll pin through the shift collar on the steering column has hogged out the shifter a little. Is there any reason I couldn't carefully drill out both sets of holes and replace with a larger roll pin to snug things up?
Old Sep 9, 2016 | 09:37 AM
dynamic's Avatar
dynamic
only problem I would see is making the pined parts weaker by making the pin size larger.
Old Sep 9, 2016 | 09:54 AM
HoustonDave
My worry too... I am hoping that the slop is small enough to allow for minimal hole expansion, plus if the parts fit snugly that removes some of the angular lever arm at the edges of the holes - hopefully that will allow it to last. Otherwise....I may screw the pooch. Hopefully not!
Old Sep 9, 2016 | 06:35 PM
ronspolv's Avatar
ronspolv
Instead of going to the next larger English roll pin size, look at replacing it with a Metric roll pin. It works out that they are slightly larger (most times) than the English size currently in there. Works on threaded fasteners also.
Old Sep 9, 2016 | 07:03 PM
Cj7clay's Avatar
Cj7clay
I also was wondering a way to fix the sloppy lever, just didn't want to make it any worse by messing with it
saemetric
Aug 16, 2015 07:48 PM
50monte
May 8, 2015 01:47 PM
76swb
Aug 25, 2013 11:32 PM
wisconsin
Dec 11, 2007 02:23 PM
ditchmedic
Jan 7, 2005 01:06 AM
