Column shifter pin
Old Aug 16, 2015 | 02:19 PM
saemetric's Avatar
saemetric
4wd Low
Column shifter pin
The pin that holds the column shifter in my 1986 F150 with automatic trans has lowered in the shift lever to the point where it barely engages in the top side of the shift collar. I can't seem to move it back upwards. How would I do this without breaking something. Can the pin be replaced or is it press fit in the lever? Need help fast!
Old Aug 16, 2015 | 07:31 PM
Franklin2's Avatar
Franklin2
If I remember correctly it's just a roll pin or a spring pin. In other words as you drive it in, it shrinks and that's what holds it in place.
I think your problem may be the spring that pushes against the lever. It may be pushing the lever off enough to were the hole is not lining up and it's resisting your efforts to push it back in place.
If you have a assortment of punches or pins, you could find one close to the hole size and stick it in the top. Use that to help line the lever back up as you try to drive it from the bottom. If you end up pulling the pin out of the bottom, make sure you do have something very close to the same size going in the hole from the top at the same time, to try and keep everything in place.
There are rare occasions when the pin splits in half and it won't stay in the hole then.
Old Aug 16, 2015 | 07:48 PM
saemetric's Avatar
saemetric
4wd Low
Thanks Dave, worked like a charm. Pin is back in place and shifter less loose.
HoustonDave
Sep 9, 2016 07:03 PM
50monte
May 8, 2015 01:47 PM
Hookster
1997 - 2003 F150
Mar 18, 2013 10:34 PM
wisconsin
Dec 11, 2007 02:23 PM
460
Oct 28, 2007 08:50 PM
