automatic shifter play
Old Sep 1, 2003 | 09:17 AM
76swb's Avatar
76swb
Got some play in my automatic column shift I want to eliminate. The split pin holding the lever itself has worn loose in the housing. Can I just drill and fit the next size pin? Also, that housing has some play on the column I'd like to get rid of. Any ideas of exactly what part is worn? Seems to be tight on the shaft.
Old Sep 1, 2003 | 09:51 AM
73-79P/ULover's Avatar
73-79P/ULover
I just put a bolt through mine and tightend it up. Works pretty good. If you care about looks you could do what our idea was.
Old Sep 2, 2003 | 02:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
If you use a bolt make sure to use one with a non threaded portion of the shank long enuf to go thru the assy. You don't want threads under the moving parts. Cut off the excess threaded portion of the bolt.
You might just want to look for a used column out of the scrapyard also.
Old Aug 24, 2013 | 05:26 AM
78cowboy's Avatar
78cowboy
what is the correct way to fix this?
Replace the
Gear SHift Insulator
Pin shift lever
and Shift colar????
l
Old Aug 25, 2013 | 09:51 AM
chris989's Avatar
chris989
Replace the
Pin shift lever
and Shift colar????
l
I ordered the collar from LMC,
Truck Parts and Truck Accessories
It comes unfinished, no paint but it looks of sound quality.
I have not installed it yet so i can not comment if it fits well. My luck with LMC is about 50%. Most items need a little adjustment.
Old Aug 25, 2013 | 11:58 AM
78cowboy's Avatar
78cowboy
nice pic - my hole for the pin is seriously elongated. I think that should work for me.
Old Aug 25, 2013 | 11:32 PM
tbear853's Avatar
tbear853
Dorman has the shft ollar as wel, comes with a new spring, pointer, roll pin as well. I used my original spring / plunger in the new collar last week when I replaced mine.
I also needed a steering wheel puller and a small cheap 3.5" Autocraft Bearing Puller ($5 @ Advance Auto Parts) to pull the upper steering shift bearing after removing the rubber piece from around it. I modified the puller by cutting the two jaws shorter.
https://www.ford-trucks.com/forums/1...witch-tab.html
Uni Moe
Aug 14, 2016 10:21 PM
PapaMatt
43
Jun 6, 2015 05:45 PM
SchwartzStock
Mar 27, 2015 10:20 PM
napass2004
27
Jul 19, 2011 07:07 AM
coolgreen
Oct 24, 2003 09:22 AM
