no heat, help!
Old Oct 30, 2011 | 09:30 AM
bruceatlom's Avatar
bruceatlom
no heat, help!
99 f250 4x4 7.3 superduty has no heat. A/c seems to work ok had similar problem last year and replaced heat control switch in dash. Same thing this year, a/c works fine but no heat when turned to red or heat setting. Blower works fine just blows cold air. Any thoughts on what may be sticking? Getting cold in MD and (excuse me but) Johnson goes full turtle on my morning ride to work. Any suggestions?
Old Oct 30, 2011 | 12:52 PM
projectSHO89's Avatar
projectSHO89
Check the coolant lines to/from the heater core. You might have something as simple as low coolant or a thermostat that's stuck open. However, if both lines are hot, then you have a temperature blend door or actuator problem.
Old Oct 30, 2011 | 01:46 PM
bruceatlom's Avatar
bruceatlom
Both lines are warm so how can I troubleshoot to see if it an actuater or blend door issue?
Old Oct 31, 2011 | 10:41 AM
bruceatlom's Avatar
bruceatlom
Found it, was the small 4 inch by 4 inch door control motor onto of heater box. Dealer part so it is just wired open for now. Thanks guy,appreciate your help.
Old Nov 1, 2011 | 05:13 AM
JWA's Avatar
JWA
Check also the temp control on the dash----could have failed in the "cold" position which natually would affect the drive motor's position.
eBay has separate new motors and blend doors if that becomes an issue. I've used heater parts from a seller there, most notably the blend door because Ford sells you the entire heater core case---blend door by itself was just at $30.
Old Nov 1, 2011 | 10:59 AM
bruceatlom's Avatar
bruceatlom
Thanks guys, turtle feels much better already. Stuck its head out earlier today but must have saw its shadow,looks like a cold winter coming our way.
BuiltFordRough
Nov 29, 2014 06:04 PM
Sabrejet
Jan 23, 2013 06:41 AM
dvani
Nov 18, 2009 12:02 PM
cobrar97
Feb 20, 2008 05:56 PM
wil057
1997 - 2003 F150
Jan 17, 2004 01:32 PM
