Sponsored by: Real Truck
Intermitten Heat (A/C) Problems
Old Feb 21, 2010 | 05:43 AM
knecoli22's Avatar
knecoli22
Hey All,
I have a '03 CC F250 7.3L.
I am finding lately that I am having intermitten issues with heating the cab (after the engine has reached optimum temp). Sometimes the heat works, sometimes it does not. Toggling the output from defrost, to floor, to vents seems to help fix the issue at times (and not at other times).
Has anyone else seen this, and if so found a resolution?
Could it be the "blend door" that I have seen some people talking about or is it possible the heating core is going to have to be swapped?
Thanks for the help!
Old Feb 21, 2010 | 06:38 AM
senix's Avatar
senix
I would be looking at the operation of the blend door. Usually (don't quote me) it works off of vacumn. But the door may be bad.
Old Feb 21, 2010 | 07:01 AM
_Rick_'s Avatar
_Rick_
Have you checked the coolant level. That would be step 1.
Rick...
Old Feb 21, 2010 | 07:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
When the heat "does not work" what symptoms are you seeing? No fan? Is it blowing out the defrosters? Air but no heat?
Old Feb 21, 2010 | 09:23 AM
MobeyDick's Avatar
MobeyDick
Rick...
That was my first thought as well!
Hardwoodpops
2004 - 2008 F150
Nov 10, 2011 11:44 AM
glamunyon
Sep 8, 2008 12:52 AM
Bobs55effie
1997 - 2003 F150
Aug 15, 2007 05:44 AM
