Thermostat Question
Old Sep 8, 2016 | 07:20 PM
roadrunner01's Avatar
roadrunner01
Thermostat Question
I recently purchased a '49 F1 which is stock (V8) except it has been converted to 12 volt. After driving it locally a few times I was concerned as temp was running between 3/4 & H. I pulled the thermostats today and they were 195F and I am going to assume the stock ones were 180F.
I have already ordered the 160F thermostats as I was concerned about the higher temps. What temp thermostats are being used here? It will be warm weather driven only and stored during winter.
Old Sep 8, 2016 | 07:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
160's are stock, or close to it. Not sure switching will cure your problems but it sure won't hurt.
Old Sep 8, 2016 | 08:50 PM
3twinridges's Avatar
3twinridges
Shoot it with an infrared and see what your temps are, it might be your gauge since its been converted.
JB
Old Sep 8, 2016 | 09:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Good point, JB. How is voltage to the gauges being reduced?
Old Sep 9, 2016 | 02:41 AM
roadrunner01
I actually had to reduce it after I bought it as it fried the sending unit.
Old Sep 9, 2016 | 03:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5PZ-8575-A (replaced 8RT-8575-B; 1BA-8575-A (150/160 degree) .. 160 degree Thermostat (Motorcraft RT-350) / Available from Ford.
Old Sep 9, 2016 | 07:48 PM
roadrunner01
Thanks for the responses, I am going to flush the system with FleetGuard Restore + as I had to drain the system to repair a water pump. The thermostats aren't here yet so it will be a couple of days before it gets done.
Old Oct 18, 2016 | 08:35 AM
roadrunner01
The thermostats were the culprit for the high temp, now I have a hard time running much above a quarter on the gauge. I'm sure flushing with restore+ helped out also. I have a set of 180 thermostats on the way to see if I can find a temp in the middle, Thanks.
jdlongmate
Feb 27, 2009 01:46 PM
JDMick
Jun 2, 2007 08:40 AM
largefries
16
Mar 14, 2007 06:23 PM
Fordman_Evs
Nov 2, 2006 07:06 PM
ocnorb
1978 - 1996 Big Bronco
Nov 19, 2005 12:55 PM
