Torque Pro Setup?
Old Sep 8, 2016 | 04:51 AM
Royson12's Avatar
Royson12
Torque Pro Setup?
I just installed torque Pro on my android and bought a wireless Bluetooth for my obd2. It seems to be communicating. But, all the different options are quite confusing. Anybody have any experience setting these up? What is a good setup? For the 6.0 4x4 with automatic trans, specifically.....Then what should I be watching for.. I will be using this on my yellow submarine, see other thread for info on that....LOL
Old Sep 8, 2016 | 06:53 AM
FordBlueHeart's Avatar
FordBlueHeart
Tons of info here on FTE about Torque Pro. Sometimes it can feel overwhelming I'm sure. I know Sean told you to start a thread asking about setup, of which there are lots of threads you can refer to for more info. Use the search function with "Torque Pro" as your keywords.
With that said, I would recommend going to the settings menu and touch the "manage extra PIDs/sensors" choice. From that screen you should see an icon or depending on your phone get to the menu feature from there and touch "add predefined set". From there, select "Ford (including Powerstroke)". This will obviously add a bunch of sensor readings specific to Ford diesels.
Back out to the main screen. Touch the settings icon again and add a vehicle profile as consistent as possible with your truck. Make sure you use English settings versus metric. Which brings up another spot to check under the settings icon under the "settings" header- "Units". Make sure all the proper boxes are checked or unchecked depending on what is asked.
I will edit this post in a little while with a link to a thread or two that explains more, IF someone doesn't beat me to the punch.
https://www.ford-trucks.com/forums/1...and-using.html
https://www.ford-trucks.com/forums/1...orque-app.html
https://www.ford-trucks.com/forums/1...auge-list.html
https://www.ford-trucks.com/forums/1...orque-pro.html
This next one is a general thread good for all diesel owners, not just Torque Pro users.
https://www.ford-trucks.com/forums/9...-pressure.html
Old Sep 8, 2016 | 10:58 AM
Royson12's Avatar
Royson12
thanks for the info, i will get started on it this evening
Old Sep 8, 2016 | 06:57 PM
happscrap's Avatar
happscrap
Diesel tech ron (rip) has a great youtube vid on setting up the torque app. In great detail. Google diesel tech ron setting up torque app...
ReddTruck
2004 - 2008 F150
15
Nov 17, 2019 03:29 PM
silverbullet6oh
Feb 9, 2017 11:32 PM
0101deven
Sep 23, 2016 12:05 AM
Thomas White
Sep 24, 2015 06:40 PM
