No start 6.0L :(
Old Sep 7, 2016 | 11:05 PM
UnrealApp's Avatar
UnrealApp
No start 6.0L :(
Ok so short and simple
I have a 2004 F350 Lariat 6.0
It cranks but will not start
I replaced the ICP 3 days ago
Recorded some data from the truck
FICM: 50 volts
FICM Sync: 1
IPR: 14.7 on / 84 cranking
ICP/HPOP: 17psi
Any ideas
Old Sep 7, 2016 | 11:15 PM
04badford's Avatar
04badford
What is ICPV volts you said 85 for IPR but you need .85 ICP to start and 540 psi , any oil on the connection or leaking out the sensor ?
Old Sep 7, 2016 | 11:37 PM
UnrealApp's Avatar
UnrealApp
No oil leak
Ill see if I can check the ipcv
Anyone have the pid for checking icpv?
Old Sep 8, 2016 | 02:05 PM
WatsonR's Avatar
WatsonR
ICP/HPOP: 17psi
You need 500 ICP to start the truck? Time for an air test. Most likely the HPOP.
a88martinez
Apr 24, 2017 12:17 PM
Tvertiz
May 7, 2015 04:22 PM
ANigrelli132
Mar 28, 2015 06:44 PM
LasVegas F250
Oct 16, 2014 02:26 PM
6.0techwannabe
May 27, 2013 07:33 PM
