They have been likened to tongue-burning rubber food generators. They boil water and heat up coffee or leftovers OK, but do not replace a grill or conventional oven. The government isn't forcing me to buy one, at least not yet.
We have a combo microwave/convection oven. It's not an enormous thing, so it won't work on a turkey (for example), but for most everyday cooking/baking things, it's the bees knees.
I topped off my tires this afternoon. My hand-held gauge read 40psi, but the TPMS is showing the LF is 39, the RR is 41 and the other two corners are at 40.
Reason: Spel chek
I would interpret that as right on, plus or minus 1 psi.
Same here. I had Goodyear do mine.. all 40 psi. Ford's TPMS is a little less reliable.. like GlueGuy says, plus or minus 1 psi. Strangely, all four gets closer to each other when I move and the tires warm up.
The super-high-end tire inflators like you find at tire shops, that run north of a kilobuck, are specced for +/- 0.3 or 0.5 psi. Your typical cheap tire gauge is (supposedly) +/- 2psi. Even if the gauge indicates down to 0.1 psi increments, it isn't accurate to that level.
When you start up in the morning, the pressure will be off because the sensors have gone to sleep to save battery life. After about 30 seconds of rotation, the sensors wake up. Your tires will also be different pressures if one side is in the sun. Drive about 3 miles to get a more accurate reading.
Great explanation. I had no idea why it'd correct itself, now that makes sense! Thanks.
This morning I decided to check the air in my tires and to also demonstrate the limits of the tpms.
The air had been checked at the dealer two days ago, but with the Temps in the upper 90's I knew the numbers should be lower this morning at a temp of 62 degrees.
As I suspected, the psi was 31.5 to 32. I aired the tires up to 35 psi per my digital guage. I also used my trusty dial guage and it showed 36 psi.
I started the truck and checked the pressure as indicated by the tpms. Both left side tires showed 36 psi, with the right side at 35 psi.
I drove approximately 2.5 miles and checked the pressure again. All four tires indicated 37 psi.
Later in the day with the temperature in the high 80's, the indicated was 40 psi for all 4 tires.
So if you do not see a flat tire when you walk out to your vehicle in the morning, do not be concerned about the tpms readings until you have driven a couple of miles.
