Headlight switch bulb
Old Sep 6, 2016 | 11:06 AM
BandBFord's Avatar
BandBFord
2006-2010 Explorer. automatic lights and fog lights
Has anyone had luck finding a replacement bulb for the headlight switch?
Thanks in advance,
BandBFord
Old Sep 6, 2016 | 09:09 PM
shorod's Avatar
shorod
I certainly would try to replace that with a white LED....
Is there a bulb number ink stamped on the bulb anywhere?
-Rod
Old Sep 6, 2016 | 10:12 PM
Mikeman's Avatar
Mikeman
-Rod
Yeah, that bulb holder looks a little crispy and overdone. An LED should be a lot cooler.
Take the bulb to a Napa or try an old-fashioned electronics shop if you have one nearby. Otherwise, some of the online electronics retailers (or even Amazon) should be able to fix you up with something.
Old Sep 7, 2016 | 05:25 AM
BandBFord's Avatar
BandBFord
Thanks for the replies. After much research it appears this is a common problem with many solutions.
I am looking into several options and will update the thread when one is settled on.
Regards,
Old Sep 22, 2016 | 04:17 PM
vicv's Avatar
vicv
every time I go to the boneyard I grab as many of the dash-switch LEDs as I can find
Old Feb 19, 2018 | 11:29 AM
SportTracer's Avatar
SportTracer
7th Gear
Headlight Switch Bulb for 2007 Explorer Sport Trac
The following bulb worked in my 2007 Explorer Sport Trac headlight switch: http://audioxpress.org/listing/05-06-07-08-09-ford-mustang-headlight-switch-light-bulb . $5.99 plus shipping. It had a blue rubber covering over the bulb, so I removed it before installing.
Also here is a link to the bulb manufacturer. It has a lot of similar type bulbs with specifications, drawings and dimensions, but not sure which bulb it is: http://www.jkllamps.com/incandescent/neo-wedgelamps
paker
1997 - 2003 F150
May 20, 2019 11:59 AM
ZSK
Mar 12, 2019 05:10 PM
qwertypert
Sep 3, 2016 03:39 AM
douglee25
Jun 14, 2007 02:45 PM
newt sweet
1997 - 2003 F150
Nov 19, 2004 08:42 AM
