Sponsored by: Auxito
Need to replace headlight
Old May 16, 2019 | 09:07 AM
paker's Avatar
paker
Headlights got damaged from minor collision. Grabbed a couple from junk yard for a hasty repair. One is the conventional headlamp with wavy front, badly hazed. The other is clear front, but focuses light to a spot. Projector type headlight seems to be the way to go. But post #2 from this thread says all direct replacement projector headlights are useless. https://www.ford-trucks.com/forums/1...l#post17106922 The post was from 2017. Is it still true in 2019? Thank you.
Old May 18, 2019 | 09:40 AM
Chad T. Keogh's Avatar
Chad T. Keogh
I decided not to go with projectors on my 1999 F-150. I went with these combined with Hella Optilux bulbs:
The after picture. Anzo headlights and Depo fog lights with Hella Optilux bulbs (blue headlight bulb, yellow fog light bulbs).
I would say that I have about a 100% increase in light on the road compared to even freshly polished stock headlight/fog light assemblies. Highly recommend them.
Old May 20, 2019 | 11:50 AM
paker's Avatar
paker
Thank you for the note. I found the same style headlight in a thrift shop, not a pair, just the passenger side, $6 brand new with film. I wanted to give it a try. It was just installed. I will experiment it this week and report back. By the way, the old one was made of plastic, but this one is an aluminum casting. Is this designed to take the high wattage light bulb? Is Hella Optilux you used a high wattage type?
Old May 20, 2019 | 11:59 AM
Chad T. Keogh
I don't think the Optilux bulbs are higher wattage than stock, just a brighter element and light generation.
WW26Red
2015 + Expedition & Navigator
Apr 16, 2020 07:34 PM
KhanTyranitar
Aerostar
46
Oct 22, 2016 03:19 AM
TxFire76
Jun 9, 2012 05:11 PM
stroker_8
Nov 9, 2010 06:44 PM
TexasGuy001
General Automotive Discussion
Nov 24, 2008 10:13 PM
