2004 explorer ignition key is stuck
Old Feb 20, 2018 | 09:39 AM
dehamma's Avatar
dehamma
I ca not get the ignition key to release from the ignition on my 2004 Ford Explorer. Any tricks?
Old Feb 20, 2018 | 12:31 PM
shorod's Avatar
shorod
Are you sure the key is turned all the way to the Off position? Are you able to turn the key to Run and Start? Have you tried repositioning the steering wheel slightly, then turning the key all the way to Off?
-Rod
Old Feb 20, 2018 | 01:33 PM
dehamma's Avatar
dehamma
I am sure of the following:
Gear shifter will go thru all positions
pressing brake
wiggled wheel from one position to the other
tilt while in al positions
everything short of replacing the ignition switch
Old Feb 20, 2018 | 02:00 PM
projectSHO89's Avatar
projectSHO89
It's not going to be a problem with the switch, it's probably going to be something worn out or broken in the linkage, mechanical interlock, or the cylinder.
Does the key/cylinder rotate properly to the position where the key is supposed to come out or is it a bit shy of that position?
Old Feb 20, 2018 | 02:55 PM
dehamma's Avatar
dehamma
I meant the cylinder when I referred to the switch. Yes all positions are normal. Vehicle starts and all positions seem to be normal.
RBerry9511
Feb 7, 2020 04:31 PM
joestanf
Dec 21, 2017 03:36 AM
texasag00
2004 - 2008 F150
May 20, 2012 02:28 PM
BLAZE12
Apr 4, 2010 07:51 PM
johnlynn
Dec 27, 2003 10:17 PM
