Speedometer Cable and 18 tooth gear
Old Sep 6, 2016 | 05:20 PM
daveengelson's Avatar
daveengelson
How many of the 4 sources that I listed did you call?
Wish U's had submitted the list earlier; contacted Carpenter and Obsolete, not impressed with the (knowledgeable)(?) tech support. I did not want to fall into my usual pattern by waiting until the last minute only to miss out. Considering the cost, I may be sore for awhile, but I feel good about the purchase.
Thank you Bill, I do appreciate the information!!
Old Sep 12, 2016 | 10:11 AM
daveengelson
Received the replacement cable couple days ago and found a tag with some blurred PN, as best as I can determine it appears to be a C7TA-17260-?. I have been assured the tag is referring to the Ford Engineering I.D. number and the item I rec's is the C5TZ-17260-N. Researched the Master Catalog, Sec. 170, pg. 5, there is what is referred to as the Identification Number, and Service Number, and not sure if it indicates there's a link between the two?
Old Sep 12, 2016 | 08:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TA-17260- is the ID Engineering number, but you're missing its suffix.
Here's a page from the parts catalog that shows ID Engineering numbers to part numbers, lots of different C7TA-17260-
Old Sep 12, 2016 | 09:18 PM
daveengelson
Thank you Bill, the tag is blurred, regardless of how hard I strain these ole peepers, and the use of a magnifying glass, it is difficult to decipher as much of the ID engineering number as I had, the suffix is not readable. Appears not sure if the cable is correct for my application and have to rely on the seller's input; however, intend removing the original cable to compare as the final check.
Again, I thank you!
mckoloum
Aug 17, 2016 05:26 PM
hest_c
Jun 27, 2016 10:43 AM
blazer350
20
Sep 11, 2013 12:50 AM
timbuctooCal
S. California Chapter
Jan 27, 2012 02:41 AM
cwdegood
May 3, 2007 06:07 PM
