speedometer cable?
Old Jul 9, 2013 | 10:40 PM
blazer350's Avatar
blazer350
speedometer cable?
i have 69 f100 with a 240 in line 6. not sure about the tranny. my question is I ordered a new speedo cable and it was the wrong one. I ordered the one that was listed for my year. the one in my truck has a plastic worm gear at the end of it. from what I can see on lmc's website and on ebay none of them have the plastic worm gear. any help out there thanks a bunch
Old Jul 10, 2013 | 12:03 AM
HIO Silver's Avatar
HIO Silver
Ummm....speedometer cables don't come with a speedo gear. Remove your gear and install on the new cable.
You're welcome... in advance.
Old Jul 10, 2013 | 10:49 PM
blazer350's Avatar
blazer350
ok the cable that they say goes to my truck the gear wont fit Im trying to get a hold of the guy I bought the truck from to see if the tranny was changed
Old Jul 12, 2013 | 01:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by blazer350
i have 69 f100 with a 240. Not sure about the tranny, my question is I ordered a new speedo cable and it was the wrong one.
I ordered the one that was listed for my year. The one in my truck has a nylon DRIVEN speedometer gear at the end of it.
From what I can see on lmc's website and on ebay none of them have the nylon DRIVEN gear.
Gear does not come with the cable, sold by itself.
1969 F100 240 I-6: There are TWO possible speedometer cables...differences based on what type of trans it has.
C5TZ-17260-N .. Speedometer Cable & Housing-64.80" long / Use with 3 speed manual (no overdrive), 4 speed manual.
C5TZ-17260-Y .. Speedometer Cable & Housing-70.80" long / Use with C4 A/T & 3 speed manual with overdrive.
If all you need is the nylon DRIVEN gear, it's available from Ford and a gazillion autoparts stores. Same 16 thru 21 tooth gears have been used for 53 years.
Old Jul 12, 2013 | 02:11 PM
Freightrain's Avatar
Freightrain
deleted......
Old Jul 24, 2013 | 09:26 AM
gwnorth23's Avatar
gwnorth23
Number Dummy Help!
I have been fighting with my f^%^*%*^ speedometer cable for a week now and have tried the $8 kits and they just aren't cutting it so before I pull the trigger on a new one at MAC's is this the right one?
C5TZ-17260-Y Ford Pickup Truck Speedometer Cable Assembly - Manual Or Automatic Transmission $23.95 EACH
Also, my gear is a 19 tooth white only. I am trying to determine what my truck should have. It has an NP435 transmission mated to a 390.
Many thanks, Mark
Old Jul 24, 2013 | 10:02 AM
CougarJohn's Avatar
CougarJohn
Blazer, the speedometers on new cars are quite accurate.
Get the speedometer on the truck working. Make sure you know the number of teeth on the plastic gear. Get alongside somebody on a freeway in a new car and have them raise their hand when they lock onto 60 mph. Read your truck gauge. You then have a number to work with and you can change plastic gear to recalibrate.
Old Jul 24, 2013 | 11:30 AM
MavSprint's Avatar
MavSprint
Do you have a GPS or a friend with one? My portable Garmin GPS shows MPH and seems to be very accurate. Since the driven gears are so cheap and easy to change, I took a guess and got a 20 tooth gear. Expect I'll have to get another when I check the speedometer against the GPS.
Be sure you have the clip that holds the driven gear on the cable. They're cheap too -- think they are $2 at Dennis Carpenter. I don't know if its possible, without the clip, to lose the driven gear in the tail housing but that would be a PITA.
Old Jul 24, 2013 | 11:48 AM
Gembone's Avatar
Gembone
Also you can get an app if you have a smart phone that will tell you your speed.
My cluster doesn't work properly, so I use my phone as my speedometer. Readings are reliable once you hit a steady speed, not so much while accelerating.
Old Jul 24, 2013 | 12:59 PM
CougarJohn's Avatar
CougarJohn
There is another option to calibrate:
If you have a tach, know the rear end ratio and measure the diameter of a rear tire, you can do some math and get mph from rpm. You must have a stick trans and it must be in direct drive, not overdrive.
This will not work on automatic transmissions because of torque converter sllppage.
Lots of good ideas coming in here.
Old Jul 25, 2013 | 05:27 AM
Alex from GA's Avatar
Alex from GA
Another way is to go exactly one mile and see, by the odometer, what the difference is. Freeways have mile markers.
Old Jul 25, 2013 | 05:46 AM
NumberDummy
C5TZ-17260-Y Ford Pickup Truck Speedometer Cable Assembly-70.80" long - Manual Or Automatic Transmission $23.95 EACH
It cannot be genuine Ford, because this cable is obsolete .. so it's a universal 'fitz-all."
What is the tire size, axle ratio, 2WD or 4WD?
C5TZ-17260-N .. Speedometer Cable & Housing Assy-64.80" long / Obsolete / 1967/69 F100 3 speed manual (no overdrive), 4 speed NP435 or Warner T-18.
C6 wasn't available until 1968: C7TZ-17260-AB .. Speedometer Cable & Housing Assy-75.42" long / 1967 F100/350 MX Cruise-O-Matic / 1968/72 F100/350 C6.
Old Sep 10, 2013 | 12:44 PM
gwnorth23's Avatar
gwnorth23
My truck has 235/75/15 tires, is two wheel drive and according to the vin code of #17 for the axle it has 3.25 - Ford (3300-lb.) rear end. Any assistance would be appreciated as the problem appears to be the nylon gear as I have replaced the cable and tested the speedo head. Thanks, Mark
Old Sep 10, 2013 | 02:51 PM
Corkwheats's Avatar
Corkwheats
Hope I'm staying on topic here -
I'm sorta in the same boat as Mark. According to the vehicle numbers, I should have a 3.50 Rear End. But when I am driving 40MPH, I'm right alongside the wife who is going 55MPH. I also have the standard 235/75/15 tires.
My friend says he thinks somebody swapped the Rear End. There can't be that many of these gears to choose from. Do I need more teeth or less teeth on my speedo gear?
Thanks,
Bob
Old Sep 10, 2013 | 02:55 PM
NumberDummy
Add teeth to slow speedo down, subtract teeth to speed it up.
How many teeth does your nylon speedo DRIVEN (end of cable) gear have now?
