1978 - 1996 Big Bronco
Changing rear Diff Fluid
Old Sep 3, 2016 | 11:32 AM
hharris8's Avatar
hharris8
I have a 86 Bronco and need to change he rear diff fluid. I opened the plug today and it was nearly a half a gallon low (been sitting for about 8 years since driving much). I filled it up for now, but there is apparently a leak and I want to change the gasket soon and get out any metal shavings there may be in there. I was not even able to siphon the old oil out because the siphon hose would not go in to the bottom because something was blocking it.
My questions is, what size diff does a 86 Bronco have?
Also, on my other truck the diff had a pumpkin cover on the rear, this truck only has the cover the drive shaft is attached to. How do I remove the cover to be able to change the gasket?
Thanks in advance!
Old Sep 3, 2016 | 01:46 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Thanks in advance!
that is a ford 9 inch you have. newer broncos got the 8.8 rear.
Disconnect the driveshaft. unbolt the pumpkin (diff cover). the whole gear set will come out. replace gasket. install back on.
Old Sep 3, 2016 | 08:58 PM
hharris8's Avatar
hharris8
Thanks, I will try that ASAP and let you know how it goes. Does the driveshaft just disconnect very simply or will it take some sort of special know how?
Old Sep 3, 2016 | 10:03 PM
ManfredVonRichtofen
Easy...just some wrenches. Also have a stop behind the tires so the truck doesn't roll back on you. Keep the transmission in gear so the driveshaft doesn't rotate.
Old Sep 4, 2016 | 06:30 AM
gatorfor88's Avatar
gatorfor88
You are going to have to slide rear axles out enough to get the center section out.
Old Sep 4, 2016 | 08:34 AM
hharris8's Avatar
hharris8
Please explain. That sounds intimidating.
Old Sep 4, 2016 | 09:29 AM
gatorfor88's Avatar
gatorfor88
you have to remove rear tires, remove brake drums. There is a hole in the axle flange you stick a socket through to remove 4 bolts that hold axle retainer on. Slide axles out about a foot. Then you can remove the center section. Just be careful because it is HEAVY. Not really that difficult a job if you have any mechanical inclination. Also you want to use some rtv sealant on the "chunk" whether you use a gasket or not.
Old Sep 4, 2016 | 10:06 AM
ManfredVonRichtofen
thats right. forgot the axles.
Old Sep 5, 2016 | 09:49 AM
hharris8's Avatar
hharris8
Thanks, I will give that a try soon.
1L243
22
Mar 26, 2017 03:41 PM
HDMustF250
Sep 29, 2011 12:32 PM
mikren
1997 - 2003 F150
Sep 9, 2009 05:48 PM
flanman4545
2004 - 2008 F150
Sep 26, 2008 08:21 PM
plumbguy
2004 - 2008 F150
Nov 21, 2004 05:11 PM
