Sponsored by: Auxito
Changed fluid in rear diff...........
Old Sep 4, 2009 | 03:27 PM
mikren's Avatar
mikren
yeaterday I changed the fluid in the rear diff . When I removed the cover the was a small bead of silicone just to say it was on the inside of the cover. I think I may have screwed up when I put the new silicone on the cover.
What I did was I put about 1/8 to a 1/4 inch bead of silicone on the inside of the bolt holes rather then the outside (on the cover) After finger tightening the bolt I did get a little oozing of silicone come out to the outside.... On my way hoe from work today I"m thinking that I must have had alot of oozing that went to the inside of the cover.
I havn't used the truck yet, it's been sitting for 24 hours letting the silicone cure properly. My question is will I be ok with some probably excessive oozing of silicone to the inside of the diff ? Being I let it cure 24 hours ?
Old Sep 4, 2009 | 03:43 PM
Mustang6147's Avatar
Mustang6147
I say ya!! I ussually use to much silicone on the rear ends, and on intake manifolds to, oil pans.... the list goes on. If it is dry let it roll...
Make sure you use the gear oil additive, so you dont get the chatter...
Old Sep 4, 2009 | 04:03 PM
mikren's Avatar
mikren
yeah I threw in 4oz of friction modifier...thanks for the quick reply.
Old Sep 4, 2009 | 06:03 PM
Ultramagdan's Avatar
Ultramagdan
You did fine. Drive it!
Old Sep 7, 2009 | 04:27 PM
mikren's Avatar
mikren
cool, thanks.
Old Sep 7, 2009 | 10:47 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
I use a gasket instead of RTV.No cure time,so just add the fluid and go!
Old Sep 8, 2009 | 07:51 AM
mikren's Avatar
mikren
would you beleive local parts stores didn't stock the gasket. They all told me to use silicone.
Old Sep 8, 2009 | 05:17 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
I did an axle seal last week. I used blue rtv silicone and have never bothered with a cure period, just fill and go. I've never had any leaks either. If you used synthetic diff fluid, like most of them call for, you probably didn't need the friction modifier. The Valvoline synthetic I used had LS additive already in it.
Old Sep 8, 2009 | 06:20 PM
green 1969 f100's Avatar
green 1969 f100
Thumbs up
Royal Purple also has LS additive.
Old Sep 9, 2009 | 05:08 PM
BlueOvalFitter
Exclamation
You will find that the fluids that "state" there is modifier in the fluid,there is not enough! You should still add the required 4oz!
Old Sep 9, 2009 | 05:48 PM
steve(ill)'s Avatar
steve(ill)
i have run into problems over the years with lube that did not have enough addative. i ALWAYS add a 7 oz tube from Auto Zone. Dont believe the service manual that 4 oz is enough.
