Sponsored by: Real Truck
Rear Differential Fluid Change
Old Mar 3, 2004 | 11:40 AM
HDMustF250's Avatar
HDMustF250
I have read a few of the posts and now I think I want to change my rear differntial fluid earlier than my normal 100k.
My question is when you folks changed the fluid did you remove the rear cover and install a new gasket?
Short of pumping out the old oil, I don't know of any other way to change it.
Old Mar 3, 2004 | 12:31 PM
ktm520mxc's Avatar
ktm520mxc
Rear differential fluid
You guessed it. Remove the cover, clean the mating surface of the cover and the differential. After the oil has drained check for any debris. Install cover with gasket or RTV and torque to specs then add fluid.
You might want to consider an aftermarket cover. I have a Mag Hi-Tec and I really like it. It has a drain plug and a dip stick, it looks great and it seals with an "O" ring.
Old Mar 3, 2004 | 01:42 PM
HDMustF250's Avatar
HDMustF250
How much does the Mag Hi-Tec Run?
Also, where is the best place to get a gasket Ford? Napa?
Old Mar 3, 2004 | 02:16 PM
ktm520mxc's Avatar
ktm520mxc
Rear Diff. cover
I think mine was around $300.00. You can check their web site.
Old Mar 3, 2004 | 02:55 PM
Urban_Prisoner's Avatar
Urban_Prisoner
I don't think there is a gasket available for the rear diff. There may be an aftermarket product available but I don't think Ford has one.
That is the main reason why I've delayed doing my diff's. I've never used gasket gunk before and I'm afraid I'll get a leaker.
Old Mar 3, 2004 | 04:35 PM
Big Orn's Avatar
Big Orn
I removed the cover and cleaned out the diff. Used the Ford gasket-maker (can't think of the brand) No gasket.
Used Mobil 1 with friction modifier (4.30 LS)
Old Mar 3, 2004 | 05:40 PM
99f350sd's Avatar
99f350sd
Yes there are gaskets for the 10.5 call Randy's Ring and pinion.
Old Mar 3, 2004 | 06:04 PM
jim henderson's Avatar
jim henderson
A lot of the rear ends use gunk. I prefer gaskets. What I did for my 94 is look at the parts book for an older model with the same rear. Usually there is a gasket for older models.
If you use just gunk, cleanliness is #1 and a nice thin bead is #2 and following directions is critical.
Good Luck,
Jim Henderson
Old Mar 3, 2004 | 06:39 PM
99f350sd's Avatar
99f350sd
I agree I used the gunk and it leaks .I now have a gasket hanging up waiting to go in when it warms up. None for the dana 50 though..
Old Mar 3, 2004 | 09:51 PM
hjestebo's Avatar
hjestebo
DIFF oil
What kind of oil should I use in the diff on a 1991 F-supper duty
Old Mar 3, 2004 | 10:53 PM
BluesManF250's Avatar
BluesManF250
other quality rear diff. covers?
I know the MAC hi-tec is a quality cover, but does anyone know of other hi quality covers that are stainless or aluminum. I am looking for one that is more noticeable (chrome) than the MAC.
Old Mar 4, 2004 | 03:56 AM
Monsta's Avatar
Monsta
Sit. Stay.
Re: DIFF oil
Usually it says right on the diff.
But you have a "supper duty" so it may say something on either the bottom of the plate or the fork.
Tee-hee-hee...welcome to FTE!
Old Mar 4, 2004 | 08:49 AM
DS02F250's Avatar
DS02F250
HDMust250,
I used Royal Purple rear gear oil ($8/qt @ Jeg's X 4 qts + handling = ~$40) fully synthetic; no friction additive necessary. The tranny shop that flushed my (automatic) tranny fluid and changed the rear gear oil for me used the "squeeze out of a tube" style gasket for the rear end. Works fine; ZERO leaks, and that was almost 5,000 miles ago!
One tip though: wait until it's warmer to change the rear gear oil. The stuff is SO thick (even my 5w-140) that it took a good effort from the tranny shop guy (a younger, pretty stout guy) just to squeeze the stuff out of the bottle and into the rear diff. He also had to make-shift a tube (rubber fuel line) to feed the oil from the bottle to the diff'l opening/filler hole... and that was a bit inconvenient even with the truck up on the lift.
My 2002 has a metal tab on one of the rear diff cover bolts that tells you what weight synthetic oil to use; maybe yours does too.
Technically, you never "need" to change the OE synthetic diff'l oil, but many FTE'rs "want" to for the sake of preventive maintenance and as a way to keep our trucks in tip-top shape mechanically.
Old Mar 4, 2004 | 09:33 AM
eckart's Avatar
eckart
I use permatex's "THE RIGHT STUFF" to seal cover plates. It's about $20.- for 1/2 a caulking tube and works great. It cost 3 times as much as other stuff I've tried but its never failed me. No matter what you use make sure you prep the two surfaces properly and the product is intended to be used for your application!
Old Mar 4, 2004 | 09:45 AM
NoMo's Avatar
NoMo
Be sure to remove the fill plug BEFORE you pop that cover off. It'd sure suck to have an empty diff and not be able to refill it because you can't get the fill plug out. I've seen a few people state they have had just that problem.
