Transmission fluid
Old Sep 2, 2016 | 07:58 PM
superdave02f552's Avatar
superdave02f552
Transmission fluid
Hi guys
Feel stupid for asking but what is the correct way to check transmission fluid level?
Do I put the words on the end of the stick right side up, if so I need to add fluid BUT if I flip it upside down I don't need fluid
About to go on my first tow away from home trip and want to be sure
Old Sep 2, 2016 | 09:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can put the dipstick in either way. Look at both sides. The lowest spot on either side that is dry is the actual level.
Old Sep 2, 2016 | 09:11 PM
superdave02f552
That's what I figured but I wanted to be sure, I knew there was a guy on here that knows about these transmissions and would set me straight.
Thanks mark!!!
Old Sep 2, 2016 | 09:13 PM
superdave02f552
Originally Posted by superdave02f552
That's what I figured but I wanted to be sure, I knew there was a guy on here that knows about these transmissions and would set me straight. Thanks mark!!!
So on my stick the words on the yellow end right side up puts the crosshatch on what would be the lowest fluid mark flip it the other way and it would show full if a guy just looked at the marks
Thanks again
Old Sep 2, 2016 | 09:48 PM
Vince79vette's Avatar
Vince79vette
Do you all check with everything off like if u were going to check ur oil?
Old Sep 2, 2016 | 11:43 PM
superdave02f552
No it says check hot engine running
Old Sep 3, 2016 | 07:36 AM
Vince79vette
U leave it in neutral or park when checking?
Old Sep 3, 2016 | 08:15 AM
superdave02f552
In park fluid hot engine running
Old Sep 3, 2016 | 01:43 PM
Mark Kovalsky
It doesn't matter. Either of those will give the same reading.
Maillemaker
Sep 29, 2018 11:16 AM
Corallis
Apr 30, 2015 02:40 PM
cmoffatt23
Mar 8, 2008 06:53 PM
KLINE925
Oct 8, 2006 10:51 PM
jb666
Sep 12, 2003 01:38 PM
