Sponsored by: Real Truck
How To Check Transmission Fluid
Old Mar 8, 2008 | 05:27 PM
cmoffatt23's Avatar
cmoffatt23
I have a 2002 F250 7.3L , i just changed the transmission fluid and am having a problem telling the level of the fluid on the white dipstick end. you cannot tell if it is in the fluid or just picking up fluid from the refill tube. I know this sounds stupid but i don't want to be driving around with low fluid. Any ideas how to tell where the level is properly?
thanks
Old Mar 8, 2008 | 05:31 PM
jhrobert's Avatar
jhrobert
If you wait long enough for the tube to drain down you will get a correct reading on one side of the stick. The other side always seem to read more. I just did mine yesterday.
Old Mar 8, 2008 | 05:41 PM
cmoffatt23's Avatar
cmoffatt23
the problem is that there does not seem to be enough fluid remaining on the dipstick to get a comfortable reading. not obvious like engine oil due to clear nature of the fluid (red but very little on the stick.
Old Mar 8, 2008 | 06:53 PM
jhrobert's Avatar
jhrobert
Try wiping the stick with a piece of chalk. Mine is easily visible on one side only.
