oil screen
Old Jul 31, 2013 | 07:55 PM
jack odom's Avatar
jack odom
oil screen
I Just completed Changing The rod and main and bearings
I need pictures, drawings or just a good description of how the oil screen and pickup tube are attached to the oil pump in a 351w The oil pump and pick up tube (new) Thee are no threads on the oil pump or the tube flange .
I should remember but some one else took off the oil pump and screen
Thanks
Old Aug 1, 2013 | 04:02 AM
baddad457's Avatar
baddad457
Sounds like someone sold you an oil pump from a 460 then. The 302/351 both had the pickup tube bolted in place with two 5/16" bolts, 180* apart from each other. If I recall the 460's had the tube pressed in place.
Old Aug 1, 2013 | 05:46 AM
jack odom's Avatar
jack odom
O;L SCREEN
I am still not clear on oil pickup screen .Does the oil pump side of the screen connection have threads (on a 351w) like the block does for the oil pump? how should it connect f I have the correct pump?
Old Aug 1, 2013 | 11:46 AM
baddad457's Avatar
baddad457
The pickup tube bolts on the pump, there are two threaded holes, one on either side of the oil passage (inlet to the pump) that are 5/16" NC in size. If there are no threaded holes in your pump on the inlet side you've got a 429/460 oil pump. The size of the pump drive will also be a clue, the 302 used a 5/16 oil pump drive shaft, everything else used a larger pump drive.
Old Aug 1, 2013 | 05:25 PM
xlt4wd90's Avatar
xlt4wd90
I could have sworn my 289/302/5.0 all used a 1/4" pump drive shaft. The 351W used a bigger shaft, maybe 5/16" but I've never measured it.
rustoleum82
Jul 4, 2016 08:41 AM
bigfoot7180
13
Oct 26, 2012 02:30 PM
yellow72f100
Feb 20, 2006 07:59 AM
kc8ard
Oct 19, 2005 08:40 AM
