Hard starting when engine hot
Old Aug 29, 2016 | 07:24 PM
Muskota's Avatar
Muskota
I have a 1992 F-150 with the 5.0 auto 2wd.
It starts fine when the engine is cold but when you get the engine warmed up and shut it off it hesitates at lot trying to start.
I had posted in a similar thread by brokeasajoke and he suggested checking the fuel pressure regulator. I haven't gotten around to checking it out yet.
I hope this is allowed. I made a youtube video of it starting when warm.
Old Aug 29, 2016 | 07:28 PM
Lead Head's Avatar
Lead Head
Your starter sounds extremely weak. I'd start by checking all the battery cables for signs of corrosion.
Old Aug 29, 2016 | 07:51 PM
Muskota's Avatar
Muskota
It only sounds like that when the engine is hot though.'
Starts fine after it has sat for several hours.
Now I have had some issues with turning the key and just getting a click. One person helped me when it did that and said it was the solenoid corroded.
However that happens just once in a blue moon and only recently.
It has been starting hard when hot for quite a while
Old Aug 29, 2016 | 07:56 PM
Lead Head's Avatar
Lead Head
Hot engines are harder to turn over. It's likely you have a wiring problem to the starter, or the starter itself is going bad.
Battery cable corrosion is an issue on these trucks.
Old Aug 30, 2016 | 08:18 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Go to an auto parts store and have them hook up a battery/starter/alternator combo tester and have them check all three while the truck is hot. Easiest stuff to check first and all three are easy to change. If all three pass then perform some ignition diagnostics.
Old Aug 30, 2016 | 06:00 PM
87 XLT's Avatar
87 XLT
Heres a very simple way to check for a bad battery cable. For the negative cable simply add a jumper cable between tthe negative battery post & the engine block. If it cranks like it should the negative cable is toast. Still no joy? add the jumper between positive battery and starter relay.
B4 doing this clean the cable ends & battery posts and reconnect the cables. grab your jumper cables and see what you get.
Old Oct 2, 2016 | 06:52 PM
88'FORD's Avatar
88'FORD
I had the same problem with my 1988 F350 7.5L. I had already replaced the battery cables so I know that is not the problem. I went to NAPA and got a starter. I changed it out and took a 30 mile trip to get the motor nice and hot. It started beautifully. The only problem I had was with the new starter. The problem was the electrical cover on the new starter was not sealed well. I hope this helps.
Old Oct 3, 2016 | 05:22 AM
Ajgsxr's Avatar
Ajgsxr
From the video it sounds like a starter issue to me. Either bad conections or the startar itself.
Old Nov 23, 2016 | 11:14 PM
Muskota's Avatar
Muskota
Well I have been using it like it was for a while.
It wouldn't start for me today. I crawled under it and found that the starter wires are extremely worn and almost broken in two in some parts.
I'll have to get it towed to a mechanic to fix it.
Old Nov 24, 2016 | 01:04 AM
Lead Head's Avatar
Lead Head
The wires aren't too hard to replace yourself.
Old Nov 24, 2016 | 02:26 AM
Muskota's Avatar
Muskota
I really don't have any experience in that.
How long are the wires? Do they just bolt on?
Old Nov 24, 2016 | 08:12 AM
brokeasajoke's Avatar
brokeasajoke
Yes wires are just bolt on. Any parts store should be able to look up wire lengths.
Old Nov 29, 2016 | 05:51 PM
Muskota's Avatar
Muskota
Update:
It turns out it was a starter all along. Took it to my mechanic and he got me a starter for $100 and put it on for $25.
blueford
Sep 2, 2007 08:49 PM
wiseguy50
May 9, 2006 11:11 AM
couleeman
Apr 29, 2003 01:06 AM
jblak687
Apr 8, 2003 09:50 AM
Rich molta
Nov 15, 1999 05:17 PM
