trouble starting engine when hot
Old May 8, 2006 | 07:31 PM
wiseguy50's Avatar
wiseguy50
Unhappy trouble starting engine when hot
hi members, gotta problem and need some advice.
my truck starts great for cold starts. it even starts great if i take a 20 min.
trip and wait 10 min. or so b4 restarting. the volt guage is charging between 14-16 volts when running. i have a new battery and starter. my problem is this:
if i take a 20 min trip or longer, park the truck for 2min. and restart, the engine barely turns over and the volt guage shows 8-10 volts. is my starter getting too hot and cant turn the engine? but it cools down after 10 min or so and turns over like a cold start. i cant figure it out, but i know someone has the answer.
thanks in advance
Old May 8, 2006 | 08:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
8-10 volts when cranking? Sounds like pretty heavy starter draw, but not out of the question. Honestly, I'd suspect the battery, but you say it's new? Is the starter a 12v or 6v running on 12? A 6v starter will draw a ton of current on 12v. How many amps is the battery rated for? Is the starter relay a 6v or 12v?
These starters are also known to have the armature rub on the windings, a common practice is to have the armature steel cut in a lathe about (I think) 50 thousandths.
Old May 8, 2006 | 09:26 PM
51ford fan's Avatar
51ford fan
I was given a real nice 53 Ford Wagon years ago that was doing the same thing. The only problem was the starter mounting bolts were loose and the armeature was dragging the field when hot.
Old May 8, 2006 | 09:39 PM
packrat56's Avatar
packrat56
A buddy of mine had a C***Y once that the allumnium pistons swelled up so much the thing would not start, or hardly crank when it was good and hot.. I dont know exactly how it ran, it was fine running, and fine starting when cool, just seemed to bind up when starting hot...
Old May 8, 2006 | 11:36 PM
pickup_289's Avatar
pickup_289
I used to have this problem and it was the coil.
Old May 9, 2006 | 12:28 AM
imlowr2's Avatar
imlowr2
Sounds like a timing problem. If the engine is too far advanced, the engine will crank really slow and sound like it doesn't want to turn over at all when its hot. Retard the timing a little and see if it improves.
Old May 9, 2006 | 07:27 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you didn't have a new starter my guess would be that the starter is dragging. Knowing what engine you have might help...
Vern
Old May 9, 2006 | 08:52 AM
fatboy92's Avatar
fatboy92
check to see if your battery cables are getting hot. could be a bad cable or a loose connection.
Old May 9, 2006 | 10:53 AM
crazyscott's Avatar
crazyscott
heres a quick and eazy solution to your problem. try getting some wrap to keep the heat away from you starter
Old May 9, 2006 | 10:58 AM
FiftySixEffie's Avatar
FiftySixEffie
Sounds like it could be a bad ground. Check the ground wire on your engine block. Did you just paint your engine? If there is not a "clean" metal to metal connection it can cause this.
Old May 9, 2006 | 11:11 AM
AXracer's Avatar
AXracer
Are you running headers? If so this is a common issue, the headers heat soak the starter. If the above suggestions don't work, add an aluminum sheet heat shield between the headers and starter. Having the headers ceramic coated inside and out will go a long way to reduce underhood heating.
