Towing While Tuned
Old Sep 1, 2016 | 06:22 PM
  #31
87crewdually's Avatar
87crewdually
Originally Posted by Phantom_9192
Hey all, I have an '03 2WD Excursion. I have an SCT tuner with Tow 55 and Tow 65 tunes (as well as a performance tune). I recently upgraded the studs (OUCH) when she started 'pushing coolant'. She has EGR delete. I've also added AirLift air bags to the back.
Now to the question.
With all of this: tuner, bolts, EGR del, air bags, 260A alt... can I tow more than the listed 11k?
I'm looking at a slightly bigger toy hauler but I'd be moving from ~6500 dry weight to ~9000 dry.
In my current config with all my stuff (race car, etc.) and full of fluids (including 100 gallons of water) I was just under 19k total and the Excursion is rated at 20k GCWR.
I'd be looking at more like 22k total with the new trailer.
Thoughts?
TIA!
This is a personal decision. Will it pull it, sure. But not knowing where or how often you're towing that kind of weight would be a deciding factor. Running heavy over weight across state lines I try to avoid. Especially on Interstates.
It becomes a legality issue, especially if something fails causing a crash with a death. That turns into a big investigation that you don't want to be a part of.
Old Sep 2, 2016 | 04:25 PM
  #32
olfordsnstone's Avatar
olfordsnstone
That's my thought too. If something catastrophic happened, as 87crewdually indicated, a good attorney could make your life miserable, calling your decision to tow overweight "gross negligence causing bodily harm or death", or something to that affect.
stangman516
Nov 29, 2008 02:06 PM
ICE FORD
Dec 3, 2007 04:39 PM
motoman97
Nov 13, 2007 08:57 PM
mrjc
Jun 25, 2007 08:03 AM
99f250
Apr 15, 2003 12:17 PM
