Trans Fluid?
Old Sep 1, 2016 | 09:20 PM
KDAVID1's Avatar
KDAVID1
Trans Fluid?
Can yall refresh my memory on trans fluid......is max life at wally world suitable? If I take out the tp filter do I need to add another qt? I believe it's normally 9qts with the 08 trans pan correct?
Old Sep 1, 2016 | 09:46 PM
Boomer89's Avatar
Boomer89
Motorcraft Mercon SP for me.
Old Sep 1, 2016 | 10:59 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I switched and now use Maxlife for all Torqshifts.
Josh
Old Sep 2, 2016 | 04:02 AM
Thor'sHammer's Avatar
Thor'sHammer
Been using maxlife in everything since it came out. Works well.
Old Sep 2, 2016 | 06:51 AM
felix4's Avatar
felix4
I'm still using Mercon SP.
Old Sep 2, 2016 | 07:08 AM
69cj's Avatar
69cj
8 quarts for the drain and 8 ounces for the filter.
Old Sep 2, 2016 | 08:45 AM
happscrap's Avatar
happscrap
Motorcraft Mercon Sp
Old Sep 2, 2016 | 11:57 AM
r2millers's Avatar
r2millers
Yep, fully synthetic and priced right. Pretty close to 2 gallons when all is said and done. Might just pick up another qt to be sure.
Old Sep 2, 2016 | 02:54 PM
diesel_dan's Avatar
diesel_dan
Yes it's 9 qts for the '08 pan, if you leave the front filter out, maybe another cup? I bought 10 when I changed pan and filter to '08, figuring it'd be about 9.5qts, but 9 did it (but I am still running a front filter)...
Old Sep 2, 2016 | 06:57 PM
KDAVID1's Avatar
KDAVID1
Awesome.....thanks as always!!!
I will be leaving the tp filter out.
fabsroman
Mar 6, 2016 09:08 PM
05 f250 6 inch lift
Jul 15, 2011 10:22 PM
TexasTornado66
May 7, 2010 01:40 AM
