c5 frontend?
Old Jan 9, 2019 | 07:16 AM
grumpyinme.'s Avatar
grumpyinme.
c5 frontend?
I just picked up a 1996 f350 srw front end,4:10 gears and limited slip info said it is a c5 front end,tried to look it up but no info,never heard of a c5,can someone have more info,I don't have tag numbers.thanks
Old Jan 9, 2019 | 08:56 AM
rla2005's Avatar
rla2005
Axle code info:
Your front axle is a Ball joint Dana 60 with 4.10 gears. The C5 reference is for the rear axle, which is a Sterling 10.25 I believe.
Old Jan 9, 2019 | 09:13 AM
grumpyinme.
Yes it has 4:10 and limited slip dif.,thank you for the info
Old Jan 9, 2019 | 09:22 AM
rla2005's Avatar
rla2005
The limited slip is in the rear axle. C5 is the code for the rear axle. It's implied the front axle is also 4.10. Without looking at the vehicle data tag on the driver side b-pillar (donor) or getting the info from the tag on the axle or opening it up you will not know for sure whether it actually has 4.10 gear and limited slip is a guess.
Johnny L
20
Apr 21, 2023 01:33 PM
dirtmister16
79
Dec 25, 2014 07:41 PM
pditmars
Jan 19, 2005 11:42 AM
Red97
Oct 6, 2003 07:03 AM
xanthias
Feb 16, 2003 08:10 PM
