Sponsored by: Real Truck
Frustrating codes
Old Aug 25, 2016 | 02:40 PM
Crawlerhauler69's Avatar
Crawlerhauler69
Frustrating codes
Hi guys I'm new to this forum I have a 2001 super duty dually 7.3 4wd just recently got all the injectors,hpop rebuilt all new sensors,new glow plugs,valve cover gaskets I also bought the auto enginuity Ford bundle heard it was a better program did all SELF tests all came back good except at 1st was getting #4 high/low so I rechecked wiring in gaskets all good after driving it eng light comes on not all the time only at cruising speeds I do have a dp-tuner and always have it in 80 economy did buzz test and it passed and just recently ohm out from IDM all 8 injectors. Where 3.1-3.2 but i still have po1316,po1211,po1274. Iv found it as really hard to find a new wiring. Harness found a junk yard 1 going threw it now is there any way to check the IDM
Old Aug 28, 2016 | 10:28 PM
IamScary's Avatar
IamScary
You ohm out the wires right as it comes out of the IDM checking each circuit for each injector? If your results were all that close (3.1-3.2) then you may have an IDM on its way out.
Old Aug 29, 2016 | 07:35 AM
Crawlerhauler69
Ya that's what I was looking at trying to find a used IDM i heard 94-03 will work I'll let u know what I come up with
Old Aug 29, 2016 | 07:50 AM
IamScary's Avatar
IamScary
You sure on the fitment? I thought 94-97 and then early 99-03.
Injectors on 94-97 will not work on a 99-03 so with that statement alone I'd avoid the older IDMs.
Old Aug 29, 2016 | 08:04 AM
Crawlerhauler69
Cool thanks I had read that they'd work but to me it did seem odd because I knew they where different I found several wreaked trucks going to find out if IDM are available
blwn350
29
Jun 8, 2017 06:57 AM
texans
Jun 28, 2012 09:23 PM
oms10
Nov 29, 2011 06:17 PM
bobert64
Mar 27, 2007 11:14 PM
mudinford
Jul 27, 2004 09:01 PM
