Idm codes
Old Jun 2, 2012 | 03:18 PM
texans's Avatar
texans
Idm codes
My buddy has a 02 7.3 that's running really ruff. Did buzz test with AE and got p0270, p1264, p1274, and p1276
First thought was uvch. Truck wouldn't even hardly stay running. Pulled valve cover and sure enough the harness was particaly unpluged. The clips were broke so I replaced the harness, but not the gasket (pins looked good). Put it back together truck runs way better, but still pretty ruff. Did another buzz test and got same codes. Also the number four sounds very week during the buzz. Where do I go from here. Is it the number 4 injector or the Idm?
Old Jun 2, 2012 | 03:29 PM
BigAlsPSD's Avatar
BigAlsPSD
Personally I do not think it's the IDM, have you ohmed out the injectors? This might help try to isolate the issue.
GB_Tech_Bulletin_103_Ford IDM_Module_Replacement (1).pdf
Old Jun 28, 2012 | 05:29 PM
texans's Avatar
texans
Update. Finnaly got back to truck. So far it has new uvc harness and gasket. Still throwing same codes. Check harness at the Idm like using the above page. Everything. checks out. What do you think? Bad Idm?
Old Jun 28, 2012 | 05:57 PM
BigAlsPSD's Avatar
BigAlsPSD
I would try swapping injectors between holes, and see if the code follows.
How many miles on the injectors?
Old Jun 28, 2012 | 09:17 PM
texans's Avatar
texans
That's funny cause that's exactly what I decided I was going to try tomorrow. And I don't know how many miles are on them.
Old Jun 28, 2012 | 09:23 PM
BigAlsPSD's Avatar
BigAlsPSD
I personally feel that you don't have an IDM issue, because they are somewhat rare, swapping injectors will help eliminate that though.
Based on your codes though, I would not swap #4 and #6 but I would swap them to the outsides like #2 and #8. Just to verify.
Powerßroke
Sep 27, 2017 09:11 AM
cwbyup2002
Nov 20, 2014 09:39 PM
Mdennis0_8
May 4, 2014 08:35 PM
fixnair
Feb 20, 2011 08:22 PM
nissandoc
Mar 18, 2007 08:54 AM
