Taurus issue....
Old Aug 19, 2016 | 09:46 PM
n7bsn's Avatar
n7bsn
Taurus issue....
On our 2001 Taurus wagon the "door ajar" light is on when ever the engine is running.
The thing is, the bell only sounds when we open a door with the keys in.
So I don't suspect the door switches, even though I have 'cleaned' the switches with massive doses of WD40 and exercising the doors.
Any idea?
Old Aug 27, 2016 | 11:13 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Cleaning a bad switch won't make it work.... as the WD40 did NOT work for you (or you didn't give it enough time OR you squirted it into the wrong area), the switch is prob bad. They are replaceable. Does the warning light tell you which door? Engine running should not matter, only with the key in the "ON" position.
Old Aug 27, 2016 | 07:27 PM
n7bsn's Avatar
n7bsn
Unfortunately all the display show is there is a door open (unlike the F350 that tells me which door).
I did four cycles of 10sec of wd40 with 10 open/close cycles, so I doubt it was "not enough", missed the mech... could be.
I'm guessing it's not the driver door, but with 5 doors (including the back door) to take apart & test (and then replace the one switch). I'm not looking forward to the troubleshooting.
Gwilkrrs
Jun 14, 2014 02:22 PM
dcara
Feb 21, 2008 05:59 PM
mach2race
Jun 8, 2006 08:33 PM
trakman
Apr 25, 2005 11:54 AM
rrs
Feb 4, 2004 12:32 PM
