Window crank part number help.
Old May 20, 2022 | 12:05 AM
mwoj's Avatar
mwoj
Is clear **** the definitive way to tell clear shank? My crew has clear ***** all around but no fancy trim. Just curious if it was an “option”.
Old May 20, 2022 | 07:21 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Not my picture got it off the internet. I never knew there where two different ones. Explains why the Lariat panels I have are worn in that area though. This should make a huge difference on the pressure put on the insert.
Old May 22, 2022 | 09:14 AM
5851a's Avatar
5851a
Check on mid late 70's LTD/Grand Marquis/Thunderbird/XR7's Any models above base model usually had the padded door panels. Check out the rear doors of 4 doors since rarely used most are in better shape.
Old May 22, 2022 | 11:29 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I can check my parts shed for a set of long shank ones. I have a box full of window cranks.
Old May 23, 2022 | 07:11 AM
73 hi-boy 428 fe
Thanks Rich, that would be awesome!
Old May 24, 2022 | 04:21 PM
77&79F250's Avatar
77&79F250
Well I found a set, but the clear handle on one is gone and the other one has a crack, so its life is short. Now if you can get a replacement **** set you are good to go. Let me know if you still want these?
https://www.autozone.com/interior/wi...B&gclsrc=aw.ds
https://www.ebay.com/itm/15363284228...%7CMake%3AFord
Old May 25, 2022 | 11:22 PM
77&79F250's Avatar
77&79F250
Should be in the mail tomorrow.
Old May 26, 2022 | 06:21 AM
73 hi-boy 428 fe
Thank you!
Walston
Apr 29, 2022 07:49 PM
frysl
Apr 10, 2018 10:28 AM
Sous
Nov 28, 2015 07:00 PM
m78
Jul 21, 2007 05:44 PM
Mitch in NC
16
Aug 4, 2004 12:00 PM
