Window crank part number help.
Old Aug 19, 2016 | 07:04 AM
hickory1991's Avatar
hickory1991
Trying to find a part number for a window crank. Supposedly they have a longer shank for the Lariat door panels. I believe this is the engineering number. D6OB-6523342-aa. So what would the part number be? Hoping Mike or ND can help.
Old Aug 19, 2016 | 07:09 AM
scott79's Avatar
scott79
I think it's D4OZ-6523342-A...I can check mine. I don't recall them being any longer but I didn't look real close!!??
Old Aug 19, 2016 | 07:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Handle, front door window regulator
Fits:
74-77 F100-500 from s/n U80,001
78-79 F100-350 (Exc. 81E)
D4TZ-1023342-A
RH & LH, includes black plastic ****, w/ depressed rings and step-down center
77-79 F100-350 (81E)
D40Z-6523342-A
RH & LH includes clear plastic ****.
I "think" model 81E is either cab and chassis or flareside. Styleside is model 99.
Also, there's no mention in the catalog about anything being different for the Lariat trim.
A little more research, Flareside is a model 83
Old Aug 19, 2016 | 08:05 AM
hickory1991
Thanks gentlemen.
Old Aug 19, 2016 | 08:47 AM
scott79's Avatar
scott79
I just pulled a few off, and here's what I found! Black ****=shorter shank, Clear ****=longer shank...My Lariat truck had clear ***** as did 2 of XLT bronco's. But my XLT trucks all had black *****...So, the clear **** window cranks do have longer shanks than the black ones!! IIRC some of the 70's cars also used the clear handles! Maybe Mike or Bill will know!!
Old Aug 19, 2016 | 09:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Fits:
D4TZ-1023342-A
D40Z-6523342-A
81E is the body style for 1973/79 XLT and 1978/79 Lariat. BA thru BT: Here are some BODY code examples for 1979.
Old Aug 19, 2016 | 09:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Bill, I learned something today.
Old Aug 19, 2016 | 04:16 PM
scottscott's Avatar
scottscott
Long shank on the left, common short on the right. The trucks with the fancy door panel inserts (Ranger XLT & Ranger Lariat) used the long shank to keep the handle from rubbing.
Old Aug 19, 2016 | 04:40 PM
hickory1991
Wouldn't happen to have two you would like to sell would you.
Old Aug 19, 2016 | 04:54 PM
scottscott's Avatar
scottscott
I do, & sent you a PM.
NumberDummy
The window crank handle won't rub on the door trim panel as long as the nylon plate, designed to keep this from occurring, is still present between the handle and panel.
C8AZ-6223370-A .. Plate-Front Door Window Regulator Handle / Obsolete ~ 143 available NOS
1968/72 F100/750 / 1968/86 Bronco / 1973/86 F100/880 // Misc: 1968/72 Passenger Cars.
Shown as 23370 in pic:
Old Aug 19, 2016 | 05:24 PM
scottscott's Avatar
scottscott
ND, the Ranger XLT & Ranger Lariat door panel inserts are about 1/4 to 3/8" thick, & mount on a standard door panel. If you force a short shank crank on to those panels, even with the nylon washer, the entire crank will rub the insert & chew it up in short order. The long shank cranks space the crank away from the panel so they do not rub.
Old Aug 20, 2016 | 09:38 AM
scott79's Avatar
scott79
Well I do agree that the longer shank window cranks are overall better for the lariat and XLT door panels. I can also state that the shorter shanks on (2) of my 79 trucks with XLT panels, are still in great condition. Both are factory originals, never changed out. BUT both trucks are low mileage (47K and 81K original miles--bought from the original owners) so this obviously plays a part in the condition. Each truck (after removing the handles) do show some "very" slight indention's on the panels from the nylon washers. Each handle also has the nylon washer on them which probably has saved the panels!!
With that being said, if you have lariat or XLT panels, the longer shanks (clear *****) would be my preferred choice to preserve the insert panels!!
Old Aug 20, 2016 | 12:24 PM
hickory1991
Totally agree with you, the longer shank will give less wear on the panel. I have driver quality panels on now, but have a nice oem set that I still need driver side stainless trim with woodgrain to complete. That is when the long shank handles will go on. Buy the way, just got back from the Woodward Dream Cruise today. Lots of cool cars and trucks. Fun making some noise.
Old May 19, 2022 | 09:57 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Old thread I know but I am looking for a set of the long shank handles. Anybody have a set to sell or a lead on where to get them?
