I just added the door panel inserts from a lariet package to my ranger door panels. now the window crank handle dosnt reach the stem very well. did lariets have different handles or stems? I called NPD but they only listed one number for the stem,and didnt think to ask about the handle. Thanks,Mark
The handles and stems are all the same no matter what model the truck is. There should also be a spring that goes behind the door panel and fits on the stem, and a plastic washer that goes behind the crank handle. If your truck is missing either of those pieces, that could be your problem.
