2004 explorer U-Joint question
Old Aug 18, 2016 | 04:53 PM
shameless's Avatar
shameless
So, I need to replace my u-joint, I've got the clips out, I've tried to press the heads of the U Joint out with a C-clamp, but no luck. anyone ever had to change one of these who can tell me what I'm doing wrong?
Old Aug 18, 2016 | 11:31 PM
shorod's Avatar
shorod
I changed the u-joints on my 2004 Aviator. I used a 6 ton benchtop press though to remove the u-joints and a bench vice to install.
Are you using the "c-clamp" intended for u-joints or a standard c-clamp? It would be tough to get enough leverage on a standard c-clamp. Also, you have an open access for the one side to extend in to, correct?
-Rod
Old Aug 20, 2016 | 08:57 AM
steve(ill)'s Avatar
steve(ill)
a 12 ton press is even better... You wont get there with a C- clamp on the newer model trucks..... That worked in 1960 --- not today.
fordsinair
2004 - 2008 F150
26
Aug 13, 2015 12:41 PM
roger54321
Oct 8, 2006 01:17 PM
hill2523
Dec 31, 2004 12:18 AM
Methalius
May 25, 2003 07:00 PM
