Door alignment
Old Aug 16, 2016 | 10:27 AM
Mzaremba's Avatar
Mzaremba
Door alignment
Could use a little input here, fellas.
I'm slowly bringing my 95 f250 xl back to life. I'm nearly there, but I'm having a bit of trouble with the final alignment of the driver's side door. The previous owner replaced it after hitting something and the body mounts were rotted away, so it hasn't lined up since I've had it. I've put in new body mounts and did the pins and bushings in the hinges. I just wanted to know if you guys had your own methods of doing it. I understand that the 4 bolts to the door adjust inward/out and the 3 bolts to the cab adjust fore and aft. I havent come across any threads that give any more info than that.
But am I loosening all bolts at once or top then bottom, etc?
My biggest issue is the door sticks out .5" or so. The front of the door seems to stick out while the back is too far in. I apologize, I don't have any pictures at the moment.
Any advice would be greatly appreciated
Old Aug 16, 2016 | 11:29 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Set your striker first, ensure you have the plastic sleeve on the striker, then align the door against the B pillar, A pillar and rocker via hinges, then adjust the front fender to the door.
-Enjoy
fh : )_~
Old Aug 16, 2016 | 04:58 PM
Mzaremba's Avatar
Mzaremba
im glad i asked. for whatever reason, i assumed the striker was the last part of the equation. thanks for the tip! giving it a go tonight
Old Aug 16, 2016 | 05:32 PM
Festus Hagen
Methanoholic
Yea, use the striker to hold the rear of the door in align with the body lines and to hold it in the correct depth.
Remember, it's a give and take situation ... Sometimes you have to go around it a couple of times to get it the way you want it.
-Enjoy
fh : )_~
jerryst
Aug 15, 2013 12:58 PM
boggerted
Jul 19, 2009 09:45 PM
1994diesel
Mar 24, 2008 11:35 PM
BGL
1978 - 1996 Big Bronco
May 31, 2005 09:44 PM
65styleside
Jun 30, 2003 11:41 PM
