starting problem.
Old Aug 16, 2016 | 01:19 AM
RadioControlGuy85's Avatar
RadioControlGuy85
starting problem.
got a 85 f150 with the 300 6 engine with 3spd
the other day i notice it would turn over slow then turn over fast like it should. did this twice, then the next day went to move it and it just makes the crazy clicking noise.
wired part is if you put a charger to it for about a 1min or 3 it will fire up. you take the charger off and turn it off it wont restart dose it again.
we installed a new started solenoid and it still dose it,
battery is at 12volts
Old Aug 16, 2016 | 05:09 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A six cell lead/acid battery should be 12.6V at rest. (ideally)
How old is the battery, and how low does it go while trying to start?
The next time you have the truck running check the voltage while you hold the engine rpm's
What does it read when your alternator is charging?
Old Aug 16, 2016 | 06:09 AM
kr98664's Avatar
kr98664
Test the battery under load. A voltage reading at rest doesn't really mean much. A marginal battery can test fine at rest but fail under the load of the starter.
While you're at it, run a voltage drop test on the cables, including the ground side.
Details of how to run the battery load test and voltage drop test are here:
https://www.ford-trucks.com/forums/1...w-starter.html
Step-by-step instructions are near the bottom of that first post. It's only three simple meter hookups, taking less than five minutes. The tests will confirm if the battery is capable of supplying adequate current under load, and if the rest of the starter circuit is delivering that current without restriction.
Old Aug 16, 2016 | 07:38 AM
Franklin2's Avatar
Franklin2
Like the others said, I bet it's not at 12v when you try to crank the engine.
Old Aug 16, 2016 | 12:07 PM
RadioControlGuy85
welp went to check it when i got up. and its dead. floor lights and dome lights are really dim, tryed to crank it and nothing.
the battery is not even a year old yet. got it last nov 15
Old Aug 16, 2016 | 12:17 PM
Tedster9's Avatar
Tedster9
Can't charge a battery in a few minutes, try maybe 12 or 18 hours at 6 amps whatever it takes, let it cook for a while when it reaches 14.5 volts or so.
Old Aug 16, 2016 | 12:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Time to start looking for that parasitic draw.
Im going to guess regulator or alternator.
Old Aug 20, 2016 | 02:47 PM
RadioControlGuy85
got my volt meter in last night.
come to find out the alternator isnt charging.
Jim-4903
Apr 6, 2014 09:28 AM
oldiron
Electrical Systems/Wiring
13
Oct 6, 2012 10:18 AM
1984-F150, 351 crate
Nov 2, 2011 07:58 PM
nothercrash
Jan 10, 2011 09:39 PM
RyanMackD55
Dec 13, 2007 07:53 AM
