Specific towing capacities?
I'm pleased to see so far from all the images and videos, the new trucks do not seem to sag much.
Like everything else this MY -- only time will tell.
bigdon68
I wasn't referring to that, rather the other differences between the 6.7 crew cab 4x4 models. Configuring the F350 and F450 as closely as you can, the F450 is still ~500# heavier, thus has 500# less payload. The lightest F350 DRW will have well over 1000# more payload than the F450.
Naturally, this limitation in payload is primarily on paper due to the 14K class 3 restriction, but not totally. If I recall correctly, you can get 10,300# springs on the F350 but are limited to 9900# springs on the F450 for 2017. There was a similar difference on the 2016 and before as well.
Plus this:
Warning: The Accessory Reserve Capacity weight information addresses FMVSS and CMVSS Nos. 204, 208, 212, 219, 301 and 303
compliance only. For all lightduty
trucks with a GVW rating under 8500 lbs., federally certified trucks with a GVW rating of 8500 to
10,000 lbs. that are optionally emission certified to lightduty
standards and all California complete vehicles with a GVW rating of
14,000 lbs. or less, if more than 500 lbs. is added to the vehicle’s “maximum vehicle weight,” the modifier may be responsible for
recertification to the applicable EPA or CARB emissions standards.
(1) Important: “Maximum vehicle weight” is calculated in accordance with the definition provided in an EPA guidance letter dated July 13, 1979,
from C.N. Freed of the EPA to M.H. McBride, legal counsel of the Recreation Vehicle Industry Association. The preceding conditions are based on
that letter and on EPA Advisory Circular No. 64 — a March 7, 1977, publication that provides guidance on the need for separate certification of
vehicles modified after original manufacture, but prior to sale and delivery to the ultimate purchaser. Additional guidance or questions concerning
EPA’s policies with respect to alterers of completed vehicles should be directed to legal counsel or the Environmental Protection Agency.
This being said I will never run and hide because I am afraid of the lawyer and the court but I will try to do the smartest job I can to comply with the rules of common sense. If the components of the truck can handle more than the rating and I know that I have no problem with exceeding said rating. But if I know those components cannot handle that weight my primary concern is for my safety (and wife/family) and then the rest of the world. If I look out for us the others will be just fine. Believe me I have soul searched these issues a lot in the build of this truck. I use a slide in camper with a wet weight of 3500 lbs. That is a pretty good load especially when one considers the high CG. I modified my current F250 to handle the weight. The new truck should be fine from the factory. If not I will have to make some changes to bring it up to snuff. If we decide to spend even more time on the road I can see going to a DRW but the SRW should handle this camper without a problem.
And I think you misunderstand how that lawsuit will go down. You won't be sued by some ambulance chaser, but by an attorney in a big, fancy office billing at $500+/hr when he hears what a slam-dunk case he has. You think he can't prove negligence? All he needs to prove are the elements of duty, breach of duty, causation and damages. Your duty is to act reasonably and follow weight limits (no brainer). You breached your duty (he shows this by simply looking at the truck and trailer stickers). The plaintiff was damaged - injured/killed (easy enough to show). The only challenge is causation. But I think that he can convince a jury of your peers that overloading must have had some cause (maybe a tire blew, of course because it was overloaded, right?). The practical reality is that your attorney, which you will have to hire at $500+/hr, will be begging the other side to settle. And when they don't, he will be pulling every rabbit out of his hat to get scientific evidence to show that the overload couldn't have contributed, which no member of the jury will believe.
I'm not saying how you should live your life. Feel free to overload and drive. People do it everyday. 999 of 1000 times nothing happens. Just like people drink and drive everyday because they are the exception, they drive just fine over .08 or whatever limit. And maybe they are right too. But when that .1% happens ….
As for me, I won't take that risk for myself, for my family who depend on me, or for the anonymous passerby to whom I owe a duty of reasonable care. Anyone else can do what they will. If anyone is going to overload, however, maybe consider putting a sign on top of your truck so if I ever cross you path I can slow down and take extra care for you.
For example, at what point does being "overloaded" create a risk? What if your rig is 5lbs overweight? 100lbs? 500lbs? 1,000lbs? Did the manufacturer inform you, as the consumer, clearly enough that you couldn't put that much weight in, on, or behind? What was the operator's intent?
I don't trust insurance companies for one minute and I'm certain you'd lose coverage...but beyond that, I think it could be murky.
And when it comes to putting a red light on top of the vehicle so other vehicles can be careful, wouldn't it be nice. But let's make sure every drunk or medicated driver does the same. Let's hook up that red light to a person's cell phone so we can all be careful when the other guy is messing with their phone. How about another red light for people who go through life looking to be offended or harmed by every little thing so we can give them a wide berth?
Rant over.
As for notice, I could see it being argued, though I have little doubt that the manner in which auto manufacturers publish their ratings is, and has been, deemed sufficient to inform consumers. At this point, a reasonable consumer "should" know, even if they don't. I wouldn't want my defense attorney having to rely on the old "my client just didn't know any better and it is his fault he didn't know" defense. It doesn't play well to juries when families of the injured/dead are crying in the courtroom.
All that said, maybe it isn't an Aaron Gordon slam dunk, but a little more difficult Steph Curry slam dunk.
On second thought, maybe I stand corrected. Given that many people on here have purchased their trucks with a whole chart of "TBD" ratings might just blow the whole case! LOL
