Upfitter Switches / Module
Old Aug 11, 2016 | 12:41 PM
  #31
Rasalas's Avatar
Rasalas
Originally Posted by Capt. Ted
My dealer couldn't believe that I didn't want the upfitter switches. With all the 12V/AC outlets, I can't imagine why I would need more switches?
I don't intend to plow snow. I will tow my boat and RV.
Am I missing something?
If you only connect 1 item the upfitter switches will be worth having. The wires are fused in the fuse block and coiled and marked under hood for connecting items: some are keyed and some are hot. Anything you choose to wire without the switches will be done by "piggy backing" in the fuse block or a wire straight to the battery. Both are questionable wiring practices which the upfitter switches and their associated wiring will circumvent.
Old Aug 11, 2016 | 12:51 PM
  #32
Capt. Ted's Avatar
Capt. Ted
Originally Posted by BII Plow Truck
For the hundred and some dollars, why not have the option to do something later? If anything, it's worth the conversation starter it makes with your passengers.
I could turn on and off all kinds of mystical things for my grandchildren with those switches, the sun, the moon, the dog whistle, traffic lights, etc..
I agree with you BII, it's a good value.With this conversation, there are things coming to mind that would be handy to have already wired. It could help the re-sale someday, also. Even if I never use them.
I would like to know if I'm giving up anything? Another place for sunglass', overhead lights, etc.?
Old Aug 11, 2016 | 01:09 PM
  #33
Rasalas's Avatar
Rasalas
I do not think so.
Old Aug 11, 2016 | 01:17 PM
  #34
Capt. Ted's Avatar
Capt. Ted
They do look pretty good. I don't like things looking out of place.
I was able to see the switches at the drive event in Ft. Wayne. I just couldn't get over all the 12V/AC connections that were standard, the front seat, the rear seat, the bed, the trailer connections. That's why I had a hard time thinking of what else I could plug in. If I have them, I'll find a use for them.
Old Aug 12, 2016 | 08:49 PM
  #35
BII Plow Truck's Avatar
BII Plow Truck
You could turn on your Flux Capacitor!
Old Aug 12, 2016 | 08:56 PM
  #36
Rutcutter's Avatar
Rutcutter
So there placed in a heck of a lot better spot than the 11-16's,we have to dig for them under the dash on these.. Another good + move
Old Aug 14, 2016 | 11:59 AM
  #37
porthole's Avatar
porthole
If nothing else, according to the posted bulletins it is a feature you cannot add after production.
Page 1
NOTE: Upfitter Switches cannot be added to a vehicle that was not built with this option at production.
Cool that the 2 extra switches can also be set to be B+ all the time. A welcome addition.
Old Aug 14, 2016 | 12:17 PM
  #38
fidel.medrano's Avatar
fidel.medrano
What do you mean by "B+"
Never mind i think i found what you meant.
Configuring Upfitter Switches 5 and 6 to Hot-at-all times.
Upfitter relay box fuse F4 (5A) can be put into one of two positions. In Position A, auxiliary switch 5 and 6, operate with the ignition in RUN or START. In Position C, auxiliary switch 5 and 6 operate hot at all times.
Old Aug 14, 2016 | 12:25 PM
  #39
porthole's Avatar
porthole
Battery 12 volts positive
ssoundwave
Mar 4, 2022 05:43 PM
thewholetruth
Mar 23, 2019 09:56 AM
Se7vinDeadlySins
Electrical Systems/Wiring
16
Dec 8, 2014 08:36 AM
f-trucker88
Aftermarket Products
27
Jul 28, 2012 05:28 AM
jugganaut$04
Dec 1, 2006 10:17 AM
