Upfitter Switches / Module
Old Aug 10, 2016 | 11:04 AM
johndeerefarmer's Avatar
johndeerefarmer
Originally Posted by EpicCowlick
I do everything I can to keep from growing up!
Add a CB radio and Bulldog on the hood and be a real trucker......
It's your truck and your money- have fun!
Old Aug 10, 2016 | 11:16 AM
Bigdon68's Avatar
Bigdon68
If you don't have the horns--- you wouldn't understand
I have Shockers on my F350 with dual compressors. The compressors are frame mounted inside of plastic battery boxes. Works great.
When your towing a 40 ft. + 5th wheel and a hotshot driver pulls in front of you then you will understand why you need air horns.
Bigdon68
Old Aug 10, 2016 | 11:17 AM
Rasalas's Avatar
Rasalas
I used to have a Husky off a Brockway on the hood. He needs re-plating but he might have to re-appear. Maybe a magnet mount? Guess not.
Sometimes horns louder than stock are needed to break through the idiot barrier. Not kid stuff pulling out in front of loaded trucks. And in this area it is mostly the farm trucks with the ***** hanging off the trailer hitch. Lot of cows in this neck of the woods.
Old Aug 10, 2016 | 11:18 AM
troverman's Avatar
troverman
I think the upfitters look cool, especially since they are now mounted aircraft style overhead. However, the only use I ever had for them was the diesel high idle, but it seems that's now a built in function?
Old Aug 10, 2016 | 11:31 AM
Rasalas's Avatar
Rasalas
I will look for that in the manual later. I believe it is only for the Cab/Chassis where items such as hydraulic pumps and heavy draw on electric are necessary.
Old Aug 10, 2016 | 11:37 AM
Rasalas's Avatar
Rasalas
Page 179.
Idle Control
Your vehicle may have a factory option for
a stationary elevated idle control through
the upfitter switches in the overhead
console. This allows the operator to
elevate the idle RPM for extended idle
periods, as well as aftermarket equipment
such as PTO operation. You must configure
this feature even if ordered from the
factory. See your authorized dealer for
required upfitting.
Old Aug 10, 2016 | 11:38 AM
Bigdon68's Avatar
Bigdon68
Upfitter switches
The switches are a great addition. I use mine not only for my air compressors, and air horn regulator but high idle and trailer camera.
My 200 psi compressors are fantastic for the the air horns but also for my air ride hitch, air bags, air to change tires, air for my air bottle jack and anything else you can come up with.
Great add on for any truck. Not just one with a bulldog.
bigdon68
Old Aug 10, 2016 | 12:09 PM
troverman's Avatar
troverman
Page 179.
Idle Control
required upfitting.
Huh, that's different. Thanks for the update.
Old Aug 10, 2016 | 12:31 PM
Rasalas's Avatar
Rasalas
Thinking further about this option I can imagine that the "upfitter module" would be required as well. It controls auxiliary functions to ensure the correct parameters are met for among others safety reasons. Some require transmission in neutral and parking brake set and I would believe high idle would require at least one of these if not both so that a high idle switch could not be activated while in a line of traffic for instance and then have the truck jump ahead in a pedestrian or another vehicle. Even a truck left in gear with the parking brake set could take off on its own if the high idle was activated. This is all conjecture on my part but these simple safety standards are bound to have been enacted by brains much stronger than mine.
Old Aug 10, 2016 | 12:57 PM
troverman's Avatar
troverman
My current truck has the upfitters (I installed them myself, guess not possible on the new truck) but certainly no module. Adding the "high idle" was as simple as a resistor soldered across two wires. Truck did need to be in Park with parking brake set.
Old Aug 10, 2016 | 01:02 PM
Rasalas's Avatar
Rasalas
The upfitter module or upfitter switches? Any way that is good to know. I would hope there would be a parking brake defeat as well. My 7.3 runs up to 1200 rpms without the parking brake when cold but kicks down immediately on touching the actual brake pedal which is required to shift out of park.
Old Aug 10, 2016 | 01:06 PM
troverman's Avatar
troverman
Upfitter switches. No module. By using a different resistor you could vary the high idle up or down. Some folks bypass the resistor and use a rheostat (volume control) ****, so they can turn the idle up or down as they please. You can certainly bypass the parking brake. The "high idle" on the 6.7L is probably 1200; normal is around 600. PCM controls it.
Old Aug 10, 2016 | 02:11 PM
  #28
archerseven's Avatar
archerseven
https://www.fleet.ford.com/truckbbas/non-html/Q-218.pdf Relevant. What it's actually looking for is a voltage, not a resistance, which means you could (I believe, though I intend to test this) use an arduino (or similar) and a MOSFET to control the SEIC. I've got clever ideas as to how to use that, but hoping to combine it with a "remote start" to give me the ability to hold a deep-cycle battery at charge, would let me keep heated blankets running overnight without idling the engine non-stop... we'll see if I actually do that or not.
Old Aug 11, 2016 | 12:20 PM
  #29
BII Plow Truck's Avatar
BII Plow Truck
Originally Posted by Capt. Ted
My dealer couldn't believe that I didn't want the upfitter switches. With all the 12V/AC outlets, I can't imagine why I would need more switches?
I don't intend to plow snow. I will tow my boat and RV.
Am I missing something?
For the hundred and some dollars, why not have the option to do something later? If anything, it's worth the conversation starter it makes with your passengers.
Old Aug 11, 2016 | 12:33 PM
  #30
EpicCowlick's Avatar
EpicCowlick
I had the scouts in the truck once and one of them asked what all the switches were for. I told them it was the secret combination to start the truck. Flip switch one twice, 3rd switch 4 times, 4th switch once and 2nd switch three times. Then start the truck. They all said, "Whooooooo" all at once. 12 year olds...
