Stressed Ford owner!!!
Old Aug 9, 2016 | 07:46 PM
Crazychris1981's Avatar
Crazychris1981
I bought a 1995 F350 4x4 with a 460 in it. Ran good for for two weeks. The first thing I noticed it see me hot. Looked around and a lot of people sad this is normal for 460s. Then it did notes that to start on the front tank but would run if you started with rear tank and switched. I went to go to town the other night started right up. Got about a block down the road and had zero power. I had to full throttle it to get it to move to make it back home. It has a Orileys crate motor in it with less then 4000 miles. New distributor, cap, plugs, wires ect. I did the self test it came up with code 23 and 33. I replaced tps and tested several others. It try's to start kinda. Diesels a little bit when you let off and it dies.
Thanks in advance for any help!!!!
Old Aug 11, 2016 | 10:12 AM
jas88's Avatar
jas88
Will it start and run on starting fluid? What is your fuel pressure at the rail?
Old Aug 12, 2016 | 11:00 PM
Crazychris1981
I got it figured out. The roll pin on the gear on the bottom of the distributor.
Old Aug 13, 2016 | 12:19 AM
Tedster9's Avatar
Tedster9
New oil pump too? High output oil pump? They don't normally break of course, something is up.
Old Aug 13, 2016 | 01:42 AM
Crazychris1981
It's an Orileys crate engine. Not sure what they put in it.
Old Sep 5, 2016 | 09:56 PM
wtroger's Avatar
wtroger
I had a customer bring me a Chevy truck with an O'reillys crate SB that had spun a rod bearing with like 35 miles on it. What I found was so much assembly lube in it that number 4 rod wasn't getting oil. I would spin the pump with a drill and see how hard it turns.
forrestj87
Sep 6, 2016 02:29 PM
Crazychris1981
75
Aug 14, 2016 07:50 PM
beckula
Oct 6, 2013 03:32 PM
gearshift101
17
Oct 27, 2004 09:12 PM
Crispyc
1978 - 1996 Big Bronco
Sep 17, 2003 09:50 PM
