2001 Excursion Cruise control stopped working
Old Aug 9, 2016 | 02:04 PM
ClayH's Avatar
ClayH
Title pretty mush tells it all, one day it work and the next day it didnt. I checked the 15a fuse and it was good. What else should I be looking at?
Thanks.
Old Aug 9, 2016 | 09:21 PM
72GTS's Avatar
72GTS
I have the same issue. Found this on the net. going to try it this weekend.
https://search.yahoo.com/yhs/search?...&hsimp=yhs-002
Old Aug 9, 2016 | 11:47 PM
superdave02f552's Avatar
superdave02f552
Originally Posted by 72GTS
I have the same issue. Found this on the net. going to try it this weekend. https://search.yahoo.com/yhs/search?...&hsimp=yhs-002
Same here worked three times on one trip but not after the fourth engage
Did what that post up there say and its fixed
Old Aug 10, 2016 | 05:13 AM
moe67moe's Avatar
moe67moe
Fixed mine a month or so ago After checking fuses, brake switches,speed sensors, etc got a 14 dollar servo off a 2000-2003 Taurus at salvage yard Works great My X ia also an 01 Good luck Ken
Old Aug 10, 2016 | 09:10 AM
zapola6's Avatar
zapola6
Mine was a servo as well. Cruise light on the dash worked, that was it, replaced the servo after I replaced the switch on the master cylinder.
You got a better deal that I did at the junk yard... Mine was $25 off of an EX that had seen better days at the yard....
Old Aug 11, 2016 | 01:01 PM
ClayH's Avatar
ClayH
I'm a little confused about your link, its full of more links? Which link specifically are you talking about?
Not even my cruise light works so does that mean its the switch I read about on the master cyl?
Old Aug 11, 2016 | 10:01 PM
72GTS's Avatar
72GTS
It's the first video it's 3:48 long. Brake switch under the master cylinder.
Old Dec 6, 2016 | 10:44 PM
HiZ's Avatar
HiZ
What's this Servo
Old Dec 7, 2016 | 01:15 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Old Dec 7, 2016 | 06:10 AM
moe67moe's Avatar
moe67moe
H1Z on my 01 X I changed the switch on the master cylinder and still had no cruise control Went to junk yard and got the servo unit off of a 2000 to 2003 Taurus as someone here recomended (Aaron Jones ?? ) Just had to change out the cable from servo to throttle body. Works as it should now Servo on my Ex is on passenger fender well Hope this helps Ken in PA
Old Dec 7, 2016 | 06:50 AM
Matt M, PA's Avatar
Matt M, PA
I went through the buttons test, checked the switch under the master cylinder..even replaced the brake light switch at the pedal. A mechanic friend suggested it was the servo at the beginning. He was right.
I found out about the Taurus servo swap just after buying a new servo from Ford...
Old Dec 7, 2016 | 05:28 PM
HiZ's Avatar
HiZ
Switch checks okay; Servo as in the actuator that holds the cable/throttle at speed? On it
Old Dec 8, 2016 | 10:25 PM
ScottieGT500's Avatar
ScottieGT500
I have issues with mine sometimes as well, I'm thinking I may have a short in my steering wheel switches, sometime it will work and sometimes it won't, I have to keep hitting the on and set to get it to engage. And once engaged the decel will not work.
bigcountry1009
Sep 25, 2018 06:26 AM
crzrlou
2004 - 2008 F150
Apr 20, 2013 08:55 PM
moose_j9
Nov 21, 2010 09:55 AM
njstevens
Apr 1, 2007 01:12 PM
99xlt4.04x4
1983 - 2012 Ranger & B-Series
Dec 12, 2003 04:55 PM
