Sponsored by: Real Truck
Salvageable?
Old Aug 7, 2016 | 07:02 PM
Santimanzano's Avatar
Santimanzano
Salvageable?
Can pick up this motor for a couple hundred bucks. Thoughts? Salvageable? I have another one from my truck that is not burned but has major issues internally.
this was in a vehicle fire. Engine still turns freely and is not seized.
Is internal damage on this likely from the fire?
Thanks
Old Aug 7, 2016 | 07:25 PM
Slowpoke Slim's Avatar
Slowpoke Slim
I wouldn't take it for free.
Vehicle fires get very, very hot. Like changing temper in steel and iron hot. Let alone the aluminum parts.
There's nothing on that engine that I would trust to use again.
Old Aug 7, 2016 | 08:03 PM
HearseDriver's Avatar
HearseDriver
As Slowpoke says. I wouldn't take it for free. If you pulled a valve cover you would see that any residual oil left on the head at the time of the fire would be cooked chunks of crud and the internals wouldn't look any better because of the heat.
Old Aug 7, 2016 | 08:36 PM
Poncho450's Avatar
Poncho450
Salvageable only to go into a furnace to make more steel.
Old Aug 7, 2016 | 09:40 PM
Spamfritter's Avatar
Spamfritter
This. I passed on a 1965 Mustang for cheap because the unibody had fire damage to it. That's about all that was left of the car anyway.
Old Aug 7, 2016 | 11:38 PM
Pocketlint's Avatar
Pocketlint
I would take a pass on buying it, unless you have a specific use for it, and you are only after a few part that you knew would be okay. Honestly it's your money you can do what you like, it could work in your favor or it could be a a 499 pound lawn ornament.
As the others have said, a vehicle fire and the temps reached will have done a lot of damage and then you have the water poured on it to put the fire out which means that the engine would have been cooled down unevenly adding to the issues this motor will have
That's just my two cents
Old Aug 8, 2016 | 12:26 AM
bigalsmith102's Avatar
bigalsmith102
Not a chance I would ever trust an internal component from that salvage. Having experienced a motor vehicle fire (my motorcycle burned to the ground), I've seen first hand what fire can do.
With only 1.5 gallons of gasoline left in the tank of my bike the fire raged so hot that the steel handlebar cross bar began to sag. The aluminum pannier MELTED. All internal seals melted and the oil boiled over. The aluminum wheels started to taco under the weight of the bike.
RUN.
Old Aug 8, 2016 | 03:02 AM
Yahiko's Avatar
Yahiko
If you don't mind taking it all the way down and checking every part.
Free would still be your best price. You won't know until you dig into it.
Save you time and $ and get one that has not been pre-toasted.
Sean <BR>
6.0L Tech Folder
Old Aug 8, 2016 | 05:19 AM
Dom165's Avatar
Dom165
As others have said, I would pass on that one. The initial price is cheap, but something like that can be very expensive in the long run. There is likely to be all kinds of hidden or unusual problems that you would not typically encounter with a "normal" rebuild. I'd keep looking.
Good luck.
Old Aug 8, 2016 | 09:26 AM
Spamfritter
Turn it into a coffee table. That's about the best use of that motor at this point.
Old Aug 9, 2016 | 09:52 PM
Santimanzano
thanks guys. I've been persuaded to pass on this. My search for an inexpensive used 6.8 liter to replace my bad one continues.
Old Aug 10, 2016 | 09:52 AM
airm4n's Avatar
airm4n
I recovered a burning duramax out in the bush before. The engine was melted into a puddle. Electrical fire the guy said he put it out with 6 different fire extinguishers from people who passed and it just kept relighting itself.
1952 Ford
Aug 5, 2016 05:41 PM
reed1951
19
Jan 14, 2014 12:49 PM
Deviousfred
18
Mar 11, 2013 04:32 AM
Medicmike63
May 2, 2009 06:10 PM
bla1879
S. California Chapter
33
Oct 21, 2008 03:40 PM
