Sponsored by: Real Truck
Broken leaf spring source of bad alignment
Old Aug 6, 2016 | 12:45 PM
TheRooster's Avatar
TheRooster
Brought my truck into the shop this morning for new tires and an alignment. Techs couldn't get the truck to align properly and eventually found that I have a broken main leaf spring.
This can cause your rear end to be out of alignment...right? It's a used truck and I'm concerned that the frame may be bent which was the techs initial instinct.
Old Aug 6, 2016 | 01:33 PM
fishbones182's Avatar
fishbones182
Leafs wear out and break. Replace both leaf packs and see what happens. Did you pull a car fax on the truck. What year truck is it? I wouldn't be overly concerned until both the leaf packs are replaced and see what the alignment does.
Old Aug 6, 2016 | 01:57 PM
TheRooster's Avatar
TheRooster
It's a 2014. It was a work truck for an oil field service company so I'm not overly surprised to be honest. I pulled both a carfax and autocheck on it before I bought it with no wrecks.
Here is a pic of the spring
Imgur: The most awesome images on the Internet
Old Aug 6, 2016 | 01:59 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
A broken main leaf can definitely throw it out of whack. If the main is broken there really isn't anything to hold that side of axle in place.
Old Aug 6, 2016 | 02:05 PM
TheRooster's Avatar
TheRooster
I see you guys sell springs. What would be your recommendation if I was to replace both packs on the truck? Its a 2014 F-250 xlt 4wd.
Old Aug 7, 2016 | 01:42 PM
fishbones182
Always replace spring packs in pairs like shocks or calipers.
Old Aug 7, 2016 | 02:28 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
It depends on the vehicle and the situation but we usually suggest replacing in pairs. It won't really hurt anything if you just do one side you run the risk of leaning and having the truck look goofy. Depends on your budget really.
Old Aug 7, 2016 | 03:38 PM
Tedster9's Avatar
Tedster9
Originally Posted by fishbones182
Always replace spring packs in pairs like socks or calipers.
Or headlights
nothercrash
17
Jul 7, 2019 12:33 PM
bassn1
Feb 4, 2009 10:37 AM
walnutcreek
Apr 16, 2003 07:22 PM
james3
Apr 12, 2003 12:46 PM
Mike 61Ford
Mar 30, 2003 07:44 AM
