1978 - 1996 Big Bronco
A/C PUMP PULLY SERPENTINE CONVERSION
Old Aug 3, 2016 | 01:33 PM
85MOTORSPORTXLT's Avatar
85MOTORSPORTXLT
Has anyone replaced the v-belt pulley on the a/c pump of a 80s (specifically a 1985) ford truck, and put a serpentine a/c pulley off a 90s (specifically a 1993 ) ford truck on the older style pump and made it work?
Old Aug 5, 2016 | 11:12 AM
Kemicalburns's Avatar
Kemicalburns
so did you install a newer 93 year motor into your 85 bronco? if so best to either swap to the newer style AC pump. I am unsure if the Serp AC clutch can be swapped to an older AC pump.
Old Aug 5, 2016 | 06:51 PM
85MOTORSPORTXLT
I am installing a 96 Ford Explorer 302.
Old Aug 8, 2016 | 11:22 AM
Kemicalburns
nice, so you will probably be best to locate the correct serp AC compressor, just take it into an AC shop so they can do the correct work so this works for you.
Old Aug 9, 2016 | 03:58 AM
85MOTORSPORTXLT
Yeah I'm leaning towards that myself, it will be a little easier
jereli
15
Jul 13, 2018 04:54 PM
99BlackF250
Nov 17, 2009 10:37 PM
JRCF
Jan 15, 2008 11:56 AM
spacedout
Oct 24, 2005 03:05 PM
