ac pump question
Old Oct 22, 2005 | 06:52 PM
spacedout's Avatar
spacedout
ac pump question
if i unplug the wire going to the clutch on my ac pump will it be stuck on or off and can i put a belt for a truck with no ac on a truck with ac? thanks
Old Oct 22, 2005 | 07:36 PM
Ford Truck Racer's Avatar
Ford Truck Racer
If you unplug the compressor it will stay in the off position, or the pully will freewheel, as far as the belts you may go to an autoparts store and check for different part numbers.
Old Oct 22, 2005 | 11:30 PM
Overkill-F1's Avatar
Overkill-F1
On some models/years, they placed a pulley in place of the a/c pump. My '90 F150, 302 requires either the a/c pump or a pulley in it's position to route the belt properly. The pulley and it's bracket can probably be found at a wrecker. ...Terry
Old Oct 23, 2005 | 06:39 PM
spacedout's Avatar
spacedout
ok thanks guys
Old Oct 24, 2005 | 03:05 PM
GWall's Avatar
GWall
You can also purchase a pulley that allows for the removal of the A/C compressor at parts stores. I found one at Advance for about $25.00.
