Injectors
Old Aug 2, 2016 | 03:01 PM
jimbo1969's Avatar
jimbo1969
Injectors
Ok I'm getting ready for this weekend to put in 2 new injectors 5 & 7 on my early 2004 6.0 this will be my first time doing injectors so what else should I do why'll I'm in there
Old Aug 2, 2016 | 03:24 PM
"Phatman"'s Avatar
"Phatman"
Take your time be cautious and keep everything clean. Inspect your standpipe Orings. Account for all tools and parts before replacing the valve cover. And for goodness sakes don't over tighten the valve cover bolts they're not all that strong. Ask me how I know
Old Aug 2, 2016 | 03:45 PM
jimbo1969's Avatar
jimbo1969
Let me guess you broke 1 or 2 but I just got done doing my oil cooler and egr cooler took me 4 days i took my time an made for sure everything was clean before taking it apart and putting it back together and that was my first time working on a diesel. thanks to you all's help I did it right
Old Aug 2, 2016 | 04:30 PM
"Phatman"'s Avatar
"Phatman"
That I did sir lol. Since you did the oil cooler you should have NO problems with injectors.
Old Aug 2, 2016 | 05:53 PM
BLADE35's Avatar
BLADE35
you have 2 bad inject in the same bank
Consider doing the all 4
if they did a balance test the result maybe Biased a leaking inject can cause others to show bad
Old Aug 2, 2016 | 08:03 PM
jimbo1969's Avatar
jimbo1969
So my be just one is bad the only code was p0275 and there's no kind of smoke just black when I put my feet in it but the dealership said I needed 5&7. I'm going to try the bubble test first want that show me the ones that bad
Old Aug 2, 2016 | 09:22 PM
robs97z28's Avatar
robs97z28
you will need a long shank torq T40 bit. I bought mine at harbor freight 1/4 in drive. worked perfect. make sure to blow all of the oil out of the bolt hole for the injector hold down.
Old Aug 2, 2016 | 10:26 PM
navistarnut's Avatar
navistarnut
If you have an early 04, ICP sensor back under the turbo, then don't worry about yanking those stand pipes out. They go bad about as often as the HPOP on the later builds do, which would be rarely.
Old Aug 2, 2016 | 11:08 PM
BLADE35's Avatar
BLADE35
P0275 Cylinder 5 Contribution/Balance
Do the Bubble test but make sure you test each cylinder individually
I Pull all glow plugs and then Install one at a time to test each cylinder when the cylinder is tested I remove that Glow plug before moving on this is very important cause if you indeed have 2 bad ones or more for that matter the bubbles generate until the Final bad inject glow plug is pulled
iv seen guys miss one pulling one GP at a time working down the line
this is very important to test individually and there is Documentation out there if you search that says just to pull one GP at a time and once bubbles disappear you found it This only works if you have 1 bad inject
Old Aug 3, 2016 | 07:09 AM
jimbo1969's Avatar
jimbo1969
Thanks I'll do the test that way night or tomorrow and let you know how it goes
Old Aug 3, 2016 | 07:35 AM
jimbo1969's Avatar
jimbo1969
Yes its early 04 the ICP is in the back
53jimc
Jun 1, 2016 06:59 PM
freedomfarmer
Dec 17, 2011 12:55 PM
droffan
Dec 2, 2011 06:59 PM
Roadglide Charley
Apr 27, 2011 04:48 PM
madone04
Mar 24, 2009 10:37 PM
