MAP Issue
Old Aug 2, 2016 | 11:32 AM
poetbig's Avatar
poetbig
MAP Issue
My MAP drops to 0 if it goes over 75 inwg when monitoring with a dashboss. The boost pressure also goes to 0. I replaced the MAP sensor and checked the line and the port on the intake manifold. The truck is running great. When I pull a heavy trailer it will trip the Power Train Code: P0299 Turbocharger/Supercharger A Underboost Condition. The truck is a F350 2006 with 75,000 miles and is stock. Thanks for any help you can provide.
Old Aug 2, 2016 | 12:11 PM
WatsonR's Avatar
WatsonR
Sounds like the range for MAP are programmed wrong on your DashBoss.
The P0299 .... clean MAP and EBP sensor. If that fixes it, great but most likely. You need to clean the turbo.
Old Aug 3, 2016 | 11:18 AM
poetbig's Avatar
poetbig
If that is the case why does the boost pressure also go to zero. I assume the boost pressure is calculated by the pickup computer and read by the dashboss.
Old Aug 3, 2016 | 03:53 PM
WatsonR's Avatar
WatsonR
Possibly they are not displaying in PSI.
Some other gauges read up to 22 and then go zero.
Old Aug 3, 2016 | 04:00 PM
BLADE35's Avatar
BLADE35
The PCM only uses voltage it's the gauge programming that does the rest to convert to psi or whatever
indyraven
Jul 9, 2014 01:47 PM
kmrbriscoe
Jul 16, 2013 11:29 PM
baredog26
Dec 9, 2010 11:30 AM
Ray 450
Jul 24, 2007 12:57 PM
Rodeohauler300
Mar 26, 2007 06:35 PM
