Sponsored by: Real Truck
Trans Temp range
Old Aug 2, 2016 | 02:27 PM
Oilfan94's Avatar
Oilfan94
Trans Temp range
2006 F350 5.4L 6 speed auto
I recently purchased an OBD2 dongle and I'm using Dash Command to give me more info gauges etc.
I was not happy to see that some of the OBD info was Ford proprietary and required an extra purchase, but whatever.
I want a trans temp gauge, and while it's easy to set up a gauge with Dash Command, I don't know what range & limits I should put on a trans temp gauge.
So does anyone know what the normal range should be...and what a warning limit should be?
Old Aug 2, 2016 | 05:02 PM
Oilfan94's Avatar
Oilfan94
I found some info on an old post...and while I do see what I've asked about...I'm seeing different numbers. https://www.ford-trucks.com/forums/9...-pressure.html
STOCK READINGS
Normal
150 - 195
Severe Service
195 - 200
Alarm
220
More Info: Tranny Temp
As for the "Factory" transmission temp gauge, it is a glorified "idiot" light as its response is severely dampened. The panel gauge will show the temp as fully warmed up at 50 *F. Between 100-220F the needle will remain in the same position on the gauge. At 230F it will move up slightly to the middle of the normal range. At 250F it will move to Yellow. The gage moves to red at 280. This is supported on page 36 of the OBDII Theory and Operations manual. The tow/haul light will flash at 275.
Over 220 is really too hot for continuous service IMO - most likely something is not right when you see temps continuously this high. Never exceed 250 for more than 30 minutes for reasons below.
Mark Kovalsky (former Ford tranny engineer) says the fluid can get to 300 for a SHORT time w/o any seal damage (however a measured temp of 250 could actually mean that some areas and parts may already be as high as 300 - normal tranny fluid is good to 300 or so, but your tranny isn't!).
So what should I set as my warning temp? The first one is saying 195-200, while the Engineer is saying 'yellow at 250'.
Also, what I'm wondering now, is whether it's the temp sensor, or he gauge that is the 'idiot light'.
In other words, if I set up an OBD2 gauge to display the precise tranny fluid temp, is the sensor going to send that info? Is it just the stock gauge that is limited...or is it the sensor that is limited?
Old Aug 2, 2016 | 09:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
2011 was the first year for the 6 speed auto. In 2006 there was a 5 speed auto.
I'd set the warning at 220°F. Anything below that is normal and no cause for concern. You don't want to be above that temp for more than a half hour at a time.
The sensor sends very accurate data good to about 1/10th of a degree. The PCM converts that to actual temperature. That's what you'll read. This data is used for calculations in the PCM, and is also sent to the dash computer. The dash computer decides where to place the needle on the dash display. This is where it gets dumbed down. You OBDII gauge will read the proper temperature.
Old Aug 3, 2016 | 01:44 PM
Oilfan94's Avatar
Oilfan94
Thanks.
I've been trying to find the specs on my Tranny. I thought I had read or heard that it was the 6 speed, so I just assumed that. The code in the door jam is 'T'....which isn't on the list around here.
*edit*
So I think I have the 5R110W....which is 5 speed...plus overdirve?
Ford 5R110W Technical Information
The Ford 5R110W transmission
is a 5 speed computer controlled transmission with lockup torque converter clutch.
It was first introduced in 2003
model year Ford F series trucks and then International CF trucksin 2004, and the Ford LFC trucks in 2005.
In “cold mode” (under 5 deg. F.) the unit shifts 1-2-3-4-6.
In “hot mode” (over 5 deg. F.) the unit shifts 1-2-3-5-6 with torque converter clutch.
Ratios: 1st gear: 3.09, 2nd: 2.20, 3rd: 1.54, 4th:1.09, 5th: 1.00 6th: .71 (overdrive)
Old Aug 3, 2016 | 02:20 PM
darkjedi351's Avatar
darkjedi351
Thanks.
*edit*
you are correct! I'm not sure why they call the 5r110 a 5 speed in that configuration when the 4r100 is a 3 speed plus overdrive but is called a 4 speed. so is the newer tans a 6 speed plus overdrive?
Old Aug 3, 2016 | 04:10 PM
Mark Kovalsky
The 4R100 is a four speed transmission. One of the four ratios is overdrive.
If you want to call it a three speed plus overdrive, why discriminate against only the overdrive? Why not call it a one speed with two underdrives (first and second gears) and one overdrive (fourth gear?)
The 5R110W is a five speed transmission. It has six ratios, but it never uses all six ratios. It uses either 1-2-3-4-6 or 1-2-3-5-6. So that's always five ratios. The highest gear, labeled 6 here, is overdrive. Fourth gear is only used when the trans is colder than 0°F, fifth gear is used when the trans is warmer than 0°F.
In 2011 Ford brought out the 6R140. That is a six speed transmission, with the two highest ratios being overdrive ratios.
Notice how the names start with a number? That number is how many ratios the trans uses.
Old Aug 3, 2016 | 04:49 PM
darkjedi351
thanks for the info! I didn't know the 5r only used one of the 2 od's. I always knew the first number was for the number of gears but was confused when I saw that the 5r had 2 overdrives.
how beneficial is it to add a radiator with a internal trans cooler to a early sd that didn't come with one for a 4r with a 6.8L? is it worth it for light to med towing? thanks!
Old Aug 3, 2016 | 09:05 PM
Mark Kovalsky
The 5R110 has ONE overdrive.
The ratios:
First 3.11:1
Second 2.2:1
Third 1.54:1
Fourth 1.09:1
Fifth 1:1
Sixth 0.71:1 This is the only overdrive ratio.
Yes, it's worth it.
Old Aug 4, 2016 | 07:40 AM
Wambo's Avatar
Wambo
Since we have broached the subject of nomenclature...
6R140:
6 forward gears
R Reverse (?)
What does the 140 signify? (Not overall spread.) Just curious. These things are seldom random.
Best,
Dan
Old Aug 4, 2016 | 09:17 AM
Mark Kovalsky
It's not random.
6 = 6 ratios
R = Rear wheel drive
140 = 1,400 lb-ft torque capacity. That is rated after the torque converter, which typically multiplies torque by 1.5:1 to 2:1.
thans1
Jul 14, 2017 01:11 AM
ScaldedDog
Oct 30, 2012 08:17 AM
hasteranger
Aug 4, 2012 04:12 PM
nico963
Apr 5, 2010 10:52 AM
F250TruckR
May 5, 2009 11:34 AM
